2012 s550 4matic w221 mercedes
Old Sep 17, 2024 | 09:33 PM
rich will's Avatar
2012 s550 4matic
Hi,I'm having issues with my 2012 s550 4matic w221 mercedes
I'm not able to crank my car and there is no power have to the key ignition, my windows won't go up or down. The car won't lock or unlock. It"s like my car is in sleep mode. My cluster doesn't have any power but my Command center and Radio do work
I replaced my SAM control unit but haven't had it programmed yet. I do believe it could be my CGW OR ZGS MODULE. If this is the issue and I find the same part # will I be able to plug and play? Any tips would be helpful.
Old Sep 17, 2024 | 10:21 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the W221.
Old Sep 18, 2024 | 06:22 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W221 forum...
Old Sep 19, 2024 | 03:46 AM
Jaap's Avatar
2006 W221 S500L M273
Don't replace any part until you diagnosed the actual issue.
You may make things worse by replacing parts and not coding them to the car.
Get a good scanner (preferably Xentry) and list all the errors here (there will be lots).
Old Sep 19, 2024 | 04:08 AM
BOTUS's Avatar
S500
I can't read ANYTHING saying the Battery is working ?
there are two SAM and it won't work correctly till programmed
