Light tap on a gas pedal creates hight RPMs and slow return to idle gear lever in N p
https://youtu.be/7dKPIf3lqOg?si=qij3CT67jedTb_eh
as a quick fix - one could try and reset the throttle damper - a silly pedal calibration using dealer tools (of course check out the many faults of doom after wiping the crap and then driving for a few mins to see what's actually real
if you are going to run an S class from more than 10 mins join this
https://mbworld.org/forums/s-class-w...a-s-n-1-a.html
I now believe this should be done whenever the Rear SAM is flashed - it seems to affect throttle usage of cruise on cars with radar cruise (distronic plus)
For now I would not touch the adaptions
I'd clear the guff about camshafts and see if it comes back - (quite normal, often its the sensors are playing up) clear and see what happens
But the coolant temp needs sorting - doubt its off the stat connector.... find another engine temp sensor and replace it ? - and or double check the software part number for the engine ECU SW - they did an update it should have had from years back
don't forget its a Merc they fit extras in software to achieve unknown goals - some later models they discovered special trick with ambient temps making them throw engine lights - and the early map also had tighter tolerances to throw camshaft position errors
Might be air intake sensor as thats showing silly....
open Xentry not Xentry simulation and you have a chance to diagnose the car not play games
https://www.reddit.com/r/mercedes_be...ver_is_closed/
And after reading the comments:
Tomorrow i'm going to my car repair shop. Stay tuned...
