Battery Maintainer Question
Old Dec 14, 2024 | 05:11 PM
Ken Wells's Avatar
2007 S550
2007 S550
I could drag out my VOM, pull the rear panel and check myself but hopefully someone has a quick answer that will save me the trouble....
I installed a Battery Tender for the engine compartment battery, will this keep the rear battery charged too, are both batteries connected?
Old Dec 14, 2024 | 05:52 PM
tx170754's Avatar
S560/SL550/LS460/Q70L 5.6 AWD
Apparently not, you need to charge them separately. The charging posts in the engine compartment are for the main battery, located behind the back wall in your trunk (your car is a 2007). To charge the auxilliary battery, the small one in the engine compartment you need a Battery Tender connected to it.
Old Dec 15, 2024 | 04:51 AM
BOTUS's Avatar
S500
if you connect it the correct way it will charge the rear - if you only go to front battery posts it will not behave
No one should these days connect direct to the posts.... cars burn so much power with the key off - you need to move to an intelligent modern charger and give things a chance by connecting using the correct points under the bonnet which aim to understand the drain - it has a longer unthreaded brass portion for the Positive connector to go on, for either the early or later cars
early cars with both front and rear batteries positive here and negative to battery post
later single battery connection positive as below and it should have a dedicated negative post (early cars don't have) on the inner wing
pdf is for the early cars
Old Dec 16, 2024 | 11:01 PM
Ken Wells's Avatar
2007 S550
I don't have a battery drain, however sometimes the car won't be used for 2-3 weeks so I would like to keep BOTH batteries topped off. Can I do that with one charger/maintainer?
Old Dec 17, 2024 | 04:12 AM
Jaap's Avatar
2006 W221 S500L M273
You don't need to.
All the idle power used by the car will be taken from the big battery in the trunk.
The small starter battery is not used at all (except for starting the car)
Old Dec 17, 2024 | 04:25 AM
BOTUS's Avatar
S500
everyone has battery drain... for starters the entire car remains awake with key off for 7 minutes, then time and temps sap power - and on modern cars alarms eat power for fun...
Buy two brand new batteries - fully charge and refit, then leave the car locked for 2 months and see if it will go - might just start - now run diagnostics the flat rear one with throw entire car in a tail spin....
Old Dec 17, 2024 | 02:40 PM
Ken Wells's Avatar
2007 S550
Thank you both for the input, I understand how it works.
Old Dec 17, 2024 | 05:26 PM
JettaRed's Avatar
Veteran: Army
I recommend you use CTEK battery maintainers. CTEK is the OE supplier to Mercedes.
