Alternator removal replacement, S550 W221 M278
thx
A red battery light appeared on Dash. OBD scan code P065B00 (stored). Replaced 5-year-old battery, power fuse box.
Put the hood in mechanic mode
Take off air box
Take out radiator fan
Loosen serpentine belt
Unbolt the passenger side motor mount from above with that special tool
use a cherry picker to lift the motor towards the driver side
Remove all alternator bolts
Weasel alternator out of there
Determine if the alternator bearings are shot
If the bearings are good, just replaced the voltage regulator
OfferUp repaired alternator to the car
Following steps are reverse of removal
Members with Mercedes-Benz repair problem generally first try AI, Google, You-tube, Microsoft Bing and so on.
Forums are popular as members who may have experienced common Mercedes-Benz repairs share experience based detailed solutions and knowledge- applicable to precise model of Mercedes.
