S-Class (W222) 2014-2020
Battery location?
Old Feb 9, 2014 | 12:15 AM
TomS's Avatar
2014 S550, 2011 E350 Cabriolet, Asgard Mothership
Does anyone know if the battery on the W222 is in the trunk like earlier models? Thanks
Old Feb 9, 2014 | 05:21 AM
DaveVY's Avatar
S 550
It is in the trunk, at least in our s550.
Old Feb 9, 2014 | 09:49 AM
TomS's Avatar
Just to check, you have the 2014 S550?
Tom
Old Feb 9, 2014 | 12:16 PM
Diesel Benz's Avatar
At the trunk floor on the S550 unlike on the W221 where it was behind the rear seat (consumer battery on the pre-facelift) or the engine bay (facelift with a single battery).
To access the battery the trunk compartment floor and the panelling below that floor needs to be removed.
Old Feb 9, 2014 | 12:28 PM
TomS's Avatar
Originally Posted by Diesel Benz
At the trunk floor on the S550 unlike on the W221 where it was behind the rear seat (consumer battery on the pre-facelift) or the engine bay (facelift with a single battery). To access the battery the trunk compartment floor and the panelling below that floor needs to be removed.
Thanks for the detailed info. I'm planning on installing an amateur radio in the trunk and I needed to get access to power. I usually hook directly to battery but I know I need to find a port behind the EIS components (ECO mode stuff). Note before anyone starts talking warranty, this is all MB-approved stuff as addressed in the owner's manual ( VHF/UHF below 35 watts of RF).
The 15 Amp plug in the trunk is plenty as I peak at 11 Amps but I was concerned about the voltage drop. If the battery is in the trunk, that might be minimal.
Just a little pre-planning.
Thanks again
Tom
37 Days to Stuttgart
Old Feb 9, 2014 | 08:00 PM
DaveVY's Avatar
S 550
Tom
Yes, and like Diesel Benz said, it is under the floor panel where the spare tire used to be before we had run flats.
Old Feb 9, 2014 | 08:09 PM
TomS's Avatar
oh of course! No more spare tire taking up needless space . Thanks!
Old Feb 12, 2014 | 08:06 AM
m3422c's Avatar
'12 S350 ('15 S550 on order)
Tom, where are you going to mount the amateur radio head unit? I will be getting a W222 in October, and will need to install a 700mhz mobile radio as we'll, and am trying to figure out the best head unit location
Old Feb 12, 2014 | 01:13 PM
TomS's Avatar
I have not made it that far yet. I will need to sit in the car with the head unit. The head unit is tiny so I am was even thinking in the sunglasses holder so I could just flip it down.
The only requirement is that when I am not using it, you need to see none of it. But that is a task for the local installer shop when I pull it in.
Tom
34 Days to Stuttgart
Old Aug 10, 2014 | 08:41 AM
edvro's Avatar
Mercedes S 350 bluetec w222 model 2015
Can the trickle charger be connected directly to the battery in the trunk of a W222?
Or can this MB-charger be connected to the 12Volt connector in the trunk? Would be easier.
Last edited by edvro; Aug 11, 2014 at 05:19 AM. Reason: Corrections and extra question.
Old Aug 10, 2014 | 04:59 PM
TomS's Avatar
Originally Posted by edvro
May trickle charger be connected directly to battery in trunc of w222?
that is how I have seen them connected in a shop. No need to pull the trunk apart that I know. YMMV.
Old Sep 16, 2014 | 08:03 PM
DATURK's Avatar
2010 HARLEY FLHTK, 2013 SL550, 2014 S63
Hi Tom,
when you are removing the liners from the trunk, did you use the torx to remove the holding hooks or do they just come out if you pull the liner up...???
seems like on my 2014 s63 there are cople of hooks hold with torx screws in the back, (i gusse i'm tyring to save some extra steps with your help)..
thnx in advance.
Old Sep 16, 2014 | 08:31 PM
TomS's Avatar
I just had the pictures and saw it mid- install. I didn't do the work. I paid the shop to install everything.
Old Sep 16, 2014 | 08:36 PM
DATURK's Avatar
thnx.
