Customized Special Order 2015 S550 - The wait begins
The tires are $400 or so a pop (probably 300 for the dealer if that!)
For $1200 - they can do you a favor on a $160,000 car to insure smoothness.
Naturally all this can be said very nicely haha.
See what they say - or compromise to do a 50/50 cost split. You spoke so highly of them - I'm sure they aren't going to go to the mattress on this.
It;s the very essence of the S Class....a comfortable right.
I am going to ask what happens to the old tires if I get the new ones, and do I have the option of putting the run flats back on. I did not ask that.
I just want to make sure I am going to want to keep the conventional tires before I have them replace the run flats. I don't want to be unfair and just have them replace the run flats just to check it out, if I don't honestly feel I am going to keep them.
As such, one will experience a different ride even if the cars use the same wheel/tire combos.
That said, forged wheels are great but will have no impact on ride quality. The car will feel more agile and steering lighter.
Runflats will always provide a harsher ride quality than a non-run flat no matter the size due to their stiffer sidewall construction.
Mercedes has definitely tell done a better job than BMW with their run flats, but I swapped them out on both brands and the ride quality improved.
This is what I have but without the tire sealant (1) or compressor (2).
Then there is this with the AMG cars.
The question is whether or not there is a styrofoam insert that can be purchased that just goes with all this equipment or is something more required.
Does anyone have a real picture of the AMG trunk storage area? This is my storage area.
This is the retrofit for the trunk that MB has for a spare.
When the car is towed, you hook the end of the towing cable into the eye and pull the car onto the flat bed.
This is much safer than trying to hook the towing cable onto the bottom of the car which will damage the front bumper.
Remove the small square bumper cover and screw into bumper.
If you look at the picture below, which is the trunk area of the S550 underneath the liner, you can see that it is completely different than that of the S63/65. The main difference is that in the S550, you have the battery installed where the styrofoam goes with all the tools in the S63/S65.
I really was surprised by this. I didn't think these cars varied that much, but apparently they do. Wonder where this battery is in the S63/S65.
Anyone know what the round metal bulb like structure is in the S550 trunk.
Picture of S550 trunk with battery
Picture of S63/S65 trunk with no battery in this location
First, I thought it was the upgraded 3D stereo, but then that did not correlate to the cars I saw.
I guess you will have to wrap the jack/tools in some kind of cloth that can double as a mat when changing the tire.
I did this to try to understand how the respective rides felt for the purpose of making a final decision on my run flats.
The consensus has been that this is not a worthy exercise, because each of the cars has a different suspension and aspects to their build.
I now understand. My S550, with run flats, drove much more smoothly than both the S65 and the S63. I was told this was by design, although I really did not expect to experience this. It was obvious. This was both on smooth roads and over road imperfections and pot holes.
Clearly, those that said this comparison would not be a worthy comparison were correct.
The dealer said that the conventional tires on my S550 would definitely be an even softer and smoother ride then the run flats.
My question is, if the ride is already better than the S63 and the S65, then should I change? The only thing that worries me is the lack of a spare. At least with the run flats, you have 50 miles at 50 MPH.
Oh, what to do.
Oh, what to do.
I've had two flats. Tow truck came - took to dealer - replaced for free and delivered car back. I do my best now to miss potholes.
Really very very good ride with the conventional. I would not go back.
And when do you exactly feel the difference? Which road conditions
I believe there is a possibility that the sport coupe steering wheel will be available in the sedan for 2016 on all AMG models and packages. For 2015, it is not available in the sedan in the US, but is available in Europe.
This will delay your production date by approximately 6-8 weeks, in addition to your already scheduled production date, a $2,500 PA1 custom order charge and then, whatever MB charges you to make the change.
haha
