OEM run-flat tread wear
The tire pressures on the placard do two things, they assure the tire will not overheat and fail at the maximum speed allowed by the limiter and they assure understeer, which regulators seem to feel is the safest alternative. What the recommended tire pressures do not do is provide even tire wear across the tread.
I have a 2015 S65 and just sold a 2006 S65 after 10 years. The V12 cars are heavier of course but I have found 42 front 36 rear provides even tire wear and much better handling along with slightly better ride quality.The reason a little more front tire pressure helps the ride is probably because more of the load is carried in the center of the tire where there is an "air spring" effect rather than on the stiffer sidewalls. This effect should be more prominent on RFT's. I have experimented with up to 48psi in the front. The handling and steering response are great but the ride seriously deteriorates at 45psi and above. If my S65 had RFT's I would swap them out.
Oh, BTW, I have 8,000 miles on mine and they still look new (less than 20% worn).
I run 39 PSI.
Sorry I know thats not a popular response here but Ive checked the wear and played with the psi and have even wear front and back on the Pirelli 20" RFT on Multispoke AMG's and I'm at 12,210 miles.
I can appreciate even the bubble that has been there in the passenger rear ever since I hit that monstrous pothole 3,000 miles ago! I have used the manufacturers psi but have likes the ride better at 40 psi rear 38 psi fronts. So far so good for me on the runflats and I already have another set in the cart ready to get another set. I've even driven them hard into off-ramps and on ramps at 80+ mph and top-speeds at over 120 mph not rattle no roll solid tracking! So I'm pleased with the product.
Do you have the standard 18" tires/wheels? I have the 19" AMG tire/wheels that come with the Sport Package. Unfortunately I cannot rotate the tires as they are staggered with the rear tires being wider than the front.
On my '14 S550 4matic with 16000 miles on it before being totaled I did not notice any problems with abnormal tire wear. Additionally I have not noticed any abnormal tire wear on my '16 S550 4matic with 8200 miles on it.
I lease, because I enjoy brand new cars. I like to get one about every 24 to 30 months or so. I very much enjoy the first part of a car's life, the later part, not so much. That's how I feel about tires. I like them when they are less than half used, the newer the better.
One could certainly say that leasing a new car every 30 months is a waste of money and depending on one's perspective, they may be right. The same goes for kicking a set of tires that are only half used. I call it preventative maintenance, peace of mind and enjoyment. What else can I say?
Thanks! Understood.
I should have said that one cannot rotate from front to rear and rear to front as you are correct. It is the front to rear that would make the most difference as both fronts wear about the same while both rears wear about the same.
Consequently I have the Continental GX SSR runflats. They are the OEMs on my '14 and '16 S550 4matics. I have had excellent luck with the Continentals. I will also replace these with the same as they have great traction in snow/ice/water in my experiences.
