S-Class (W222) 2014-2020
EURO OEM REAR FOG LIGHT
Old 03-04-2018, 07:54 AM
dakare46's Avatar
Hello, saw few s63 sedans with that mod, I understand rear bumper diffuser needs to be replaced. Does anyone know how do do this mod, looks really amazing. Thanks in advance.
Old 03-06-2018, 06:29 PM
dakare46's Avatar
Anyone?
Old 03-06-2018, 06:39 PM
Carfan500's Avatar
S560
I dont understand what you are saying. Do you have a picture?
Old 03-06-2018, 08:35 PM
dakare46's Avatar
Euro spec s63 sedan has a rear fog light in the rear diffuser between exhaust pipes.
Carfan500 (03-07-2018)
Old 03-06-2018, 10:09 PM
dakare46's Avatar
Old 03-06-2018, 11:40 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Only issue is it's BRIGHT and you are going to crate road rage behind you. It's clear leds, and turns red when the fog is on, and it's bright.
Old 03-08-2018, 12:42 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Fog Lights? " turns red when the fog is on" Red when driving and Clear when in reverse makes more sense....
Old 03-08-2018, 01:35 PM
Jason B's Avatar
Correct, it doesn't turn on with reverse, just for fog feature.
"This high intensity light is meant to be illuminated during periods of inclement weather such as fog, smoke or heavy precipitation thereby preventing a rear end collision by a following vehicle.
It should not be used during normal visibility conditions as its brightness can dazzle following drivers. It is about as bright as flashing the brake lights. The further away from the vehicle you are the brighter they become.
20 feet away and they are blinding. Trust me if this light is turned on when visibility is normal the guy behind you is going to be very pissed off. Much brighter, very much brighter than any other light on the rear of the vehicle.
Some US drivers misuse the light, I think, because they don't know what its real purpose is and its deleterious effect on following drivers when visibility is good."
ALso, the whole housing doesn't light up, only a certain portion:
Carfan500 (03-08-2018)
Old 03-08-2018, 11:11 PM
Nice Ride's Avatar
So is there a FogLight button? Is the last photos, they are red, not white.... Thanks for the photos and information. In the photos, it basically looks like a 4th Brake Light. Not Clear white light... How do you actually activate them?
Thanks again....
Old 03-09-2018, 11:39 AM
Jason B's Avatar
Correct, it's a clear lens, clear led, that TURNS RED when on. This is on the EURO spec S class, Not usa.
Old 03-09-2018, 11:41 AM
jenz's Avatar
S, GL
Here's my thread - I had it done
https://mbworld.org/forums/new-s-cla...ight-w222.html
Old 03-09-2018, 12:03 PM
Jason B's Avatar
Care to share more info? That post doesn't say much. Cost? How did you set it up to function? Separate switch, or did you get an OEM switch?
Old 03-09-2018, 07:57 PM
jenz's Avatar
S, GL
I think the cost is in the link
Shop installed it with a small discrete button in the overhead console, could not get the OEM switch to work
I don't recall the labor but wasn't crazy
Quick Reply: EURO OEM REAR FOG LIGHT
