S-Class (W222) 2014-2020
no 12v socket in armrest - surprised - can we add one? anyone add qi charger?
Old Mar 15, 2018 | 12:11 PM
garygnu's Avatar
2016 S550 4 Matic Sport, 2015 BMW 528xi, 2012 BMW 528xi (gone), 2011 BMW Z4 (Yellow - gone)
hi - i saw some posts about the rear seat qi charger - and what a disaster it is!
my S550 has something weird - a little cell phone holder (good luck holding my samsung s8+!) - when i removed it with a little elbow grease there was a nice hole behind it - i guess an access panel to do what you have to do.
i was really surprised there was no 12v socket in there (my BMW has one) - i know there's the ashtray (my BMW has another 12v in the cup holder). i'd rather not have a charger sticking out for my phone - i'm toying with the idea of buying a $30 or so qi charging pad for my phone (like the newer S's have, but not exactly). i will say, i had a charge and media cradle in my BMW, and would keep forgetting my phone in the armrest - so i'm really on the fence.
the samsung can take a fast charge, with an appropriate car charger - if i just use the USB (i am for now, i routed the cord out of the armrest) i can charge it, but not quickly. one thing i really like about qi is that there's NO wear and tear on the charging jack.
Anyway, any advice or suggestions appreciated!
Old Mar 15, 2018 | 12:41 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Cell phone mounting options in the W222 SUCK. The only real option is in the console plugged into the USB's there, or having a cord come out of the ashtray. There are not really any nice mounts that I have seen as well. I have the warmth and comfort package so my center console is literally 1" deep. Storage and cupholders are a huge miss with this car. I get that it is not a minivan but jeez, more plugs and storage areas are better.
Old Mar 16, 2018 | 07:28 AM
garygnu's Avatar
Thanks. My console is sizable even with warmth and comfort package. I bought a $20 qi pad that may do the job, I don’t plan to keep it visible ( eyesore ).
Old Mar 16, 2018 | 10:18 PM
Matthayes3741's Avatar
Veteran: Navy
2014 S550
QI Charger
I purchased and installed a QI charger for the front seat. I think it looks and works great. I just need to mount/secure the QI charger with double sticky tape. Link below to the video...
Old Mar 17, 2018 | 05:18 PM
platt-deutsch's Avatar
2019 S450
I pluged my fast charger into the 120 volt outlet in back seat and it works great. I cant get a fast charge out of the UJSB ports in the cnter console.
Old Mar 17, 2018 | 07:04 PM
garygnu's Avatar
Great idea about the fast charger using the back! My kids would likely kick it, and I can’t believe there’s no 12v in the armrest, MUST be a way to get one in there with only minimal effort, I’d Imagine.
Old Mar 17, 2018 | 07:06 PM
garygnu's Avatar
https://youtu.be/mdKmzxopgQc
looks awesome, and cute pic of kid. Was going to ask you about the all important cup holders but you showed still work. I ordered a thicker pad yesterday with the intent of using in the armrest - maybe I’ll buy a thin one and do what you did. I’d prefer not to use the console, I’d Forget my phone inside.
ALMOST wish no cd changer - finicky, and takes up room where we could otherwise slide the charger if not mounted. Maybe instead of tape use black weak Velcro (versus the super strong plastic type)
Old Mar 17, 2018 | 07:52 PM
Veteran: Navy
2014 S550
Thanks! The cup holders are definitely important and I knew the armrest wouldn’t work for the same reason you mentioned... I’d forget my phone! The way I did it still allows me to use the cigarette lighter to plug in usb chargers for things like my iPad or if someone needs a charge without a wireless charging phone. I did not have to modify or break anything to run/hide the wire but you have to remove the wood cover and ashtray in order to hide the wire. Once you figure that out it’s easy....
Here’s a link to remove ashtray:
The video mentions two clips to remove the wood cover... it took me a while to figure that out but hopefully this helps explain it a little better:
Old Mar 17, 2018 | 08:27 PM
garygnu's Avatar
Thanks! I like how you did it. I don’t want to waste the lighter socket. I may see about having a radio shop run a circuit to the fuse panel. Also toying with a 12 v socket in the armrest. On the fence. Your solution is slick though - really slick might be to tap in a microbes either with the ones in the arm rest (neatly)or even tap in a new 12v socket hidden near the fuses, then run an adapter and cables from there. Probably overkill.i don’t want to damage the wood. Maybe I could run 2 usb cables near (below)the ashtray for power...
Old Mar 17, 2018 | 08:33 PM
garygnu's Avatar
I’m still thinking about how you did it, and what improvements (if any) I can think of. My s8 car chargers allow fast charging, and have 2sockets. I MIGHT want to run a micro usb (for the fast charging), an iPad/iPhone cable (for wife/kids), AND maybe a usb-c for when I really need the phone topped off in a hurry. Any issue with 3 cables fitting?
is your qi charger particularly thin? Amazon and eBay have a ton, my older Samsung slow is shiny/slippery, so I want something thin that has some grip on both sides. Any recommendations? Thnaks!
Old Mar 17, 2018 | 10:00 PM
Veteran: Navy
2014 S550
For me o just ran what I figured would get used 90% of the time. I figured the rare occasions that I need to charge my iPad I can just unplug from the cigarette lighter and plug in an iPad charger... on the very rare times when I need to charge both, I can just charge my iPad from the console. The real problem is that when I have a drink in the car, I cannot charge my phone unless I use the console.
Link below for the charger that I bought:
Amazon Amazon
Old Mar 24, 2018 | 02:32 PM
garygnu's Avatar
https://youtu.be/NeY4kXJTmkI
I still can’t figure it out. Don’t want to damage anything. I spent some time with a spudger to no avail. Can you please explain how to get the wood off? I’ve viewed the video also a few times, bery frustrated, many thanks!
Old Mar 24, 2018 | 02:48 PM
Veteran: Navy
2014 S550
You only have to use a screwdriver or dash removal tool to push down on the two tabs then pull the wood piece towards you. The two tabs are touching my blue dash removal tool. Be patient and it will come off. Note: you don’t have to insert the tool very deep to reach/depress the tabs.
Ive had a terrible cold for three days otherwise I would shoot a quick video.
Old Mar 24, 2018 | 03:53 PM
garygnu's Avatar
many thanks, feel better. I ‘be been trying to use a spudger and also a hotel room key (thin credit card type plastic) to no avail. I have been trying to lift versus pull towards me, I’ll Try again...
Old Mar 24, 2018 | 05:04 PM
garygnu's Avatar
Success! After about ANOTHER 20 minutes, with the help of Matt’s photos, I managed to find the two plastic tabs to depress, pulled the wood towards me, and had success. Sort of.
i bought multiple cables to run; the space is small, that’s only 1 cable for me. The charging pad (thinnest I could find, I think the same as matt’s) supports fast charging but unfortunately has the connector attached. As in, damage that wire and throw out the charger.
i had to route the wire so it wouldn’t rub, not sure I did it well. I may go back and file some grooves into the ashtray areas for the cable or even more cables.
Another bummer - my Samsung fast charger is waaaaay too big, I’ll look at matt’s Video again and seek a mini fast charger, or else a mini regular charger. Still, cup holder works, and I didn’t break the wood trim, so success. I will say, I’m not even sure it is real wood, there was plastic underneath. That was a little disappointing.
i’ll attempt to post photos in case this helps anyone.
Old Mar 24, 2018 | 05:16 PM
garygnu's Avatar
Mostly finished, maybe undo and tuck wire better
Wood? Looks like plastic
Routing wire under metal ashtray part to avoid kinking, I hope
Wood removed, route the wire. Notice plastic tabs
Samsung charger is huge. Too huge, can’t close
Old Mar 24, 2018 | 08:13 PM
channey's Avatar
2015 S550
This worked for me. Still can't close it when the USB cord is plugged in, though.
Amazon Amazon
Old Mar 24, 2018 | 08:30 PM
Veteran: Navy
2014 S550
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
i ordered the same one...it closes. You just have to turn it 90 degrees so the plugs are side by side and not on top of each other.
Old Mar 24, 2018 | 11:00 PM
garygnu's Avatar
ha! I ordered the same one earlier today, hope it arrives Monday.
did you file anything or make tiny grooves for the wire? It feels very thin and flimsy. I like how thin the pad is. Deciding whether to use double sided tape or weak Velcro. I think tape to make it more permanent, no easy way to remove without removing the wood or ashtray.
still amazed no 12v outlet in armrest, I may have one installed there, maybe in the middle of that plastic small cell phone holder.
Old Mar 26, 2018 | 07:13 PM
garygnu's Avatar
Well charger arrived and works, but no fast charge. Did fast chRge with my Samsung charger...so, ew mission, find ultra mini fast charger. I will say I was able to close with the unit plugged in, so that was good. I THINK with my phone going full bore (hotspot, gps) that the charge was having it break even and not increase battery percentage.
Old Mar 27, 2018 | 01:23 AM
Detailingdoc's Avatar
2009 C350, 2015 S550
Maybe this one will work although it only has one port.
AUKEY Car Charger, Flush Fit Quick Charge 3.0 Port for Samsung Galaxy Note8 / S8 / S8+, LG G6 / V20, HTC 10 and More https://www.amazon.com/dp/B01KZHKF4I/ref=cm_sw_r_cp_apa_gsDUAbCNWJ9S1
Old Mar 27, 2018 | 07:32 AM
garygnu's Avatar
Thanks, i bought that exact one last night, I thought I uploaded the photo, guess not. I’ll,wager this takes care of it, thanks!
Old May 28, 2018 | 10:05 PM
alexpush's Avatar
s550
Did anyone notice that this charger is super slow?
Amazon Amazon
Old May 28, 2018 | 10:10 PM
Yea it says its a fast charger even on the phone it says fast charging but doesnt charge anywhere near as fast as my regular plug in home charger.
Old May 30, 2018 | 11:22 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Does that charge at the 2.1 amp?
