S-Class (W222) 2014-2020
Hydraulic Whine noise
Old Apr 27, 2019 | 06:47 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
In the morning when it is cold I notice that when I gently apply the brakes I have a hydraulic whine sound coming from around the brake pedal. Clearly tied to the brakes but not sure what it could be. When I firmly hit the brakes it is not present and when I drive the car for a while it goes away until it sits for a while again. Not very loud but annoying. Could it be air in the brake lines causing a high pitched pulsation or something else. Thanks.
Old Apr 28, 2019 | 06:54 PM
superpop's Avatar
Anyone?
Old Feb 25, 2020 | 11:44 AM
GDGD's Avatar
Mercedes S350
Braking noise
Originally Posted by superpop
Anyone?
Hi - yes, I have the same problem on my W222. Did you resolve your issue ?
Old Feb 25, 2020 | 12:49 PM
roviw1's Avatar
2015 S500, 2016 GL63 AMG
I could possibly suggest the " pulsation damper ", am I guessing you are in the USA and not Newcastle UK ?
The reason I mention that is in my 2015 S500 I had a noise ( in the UK here so RHD car) from the front passenger footwell area , it was the pulsation damper, a friend also had it on his 2008 CL600..
Mine was covered by my used car warranty but I would suggest it might be worth looking into that suggestion.
Old Feb 25, 2020 | 12:51 PM
GDGD's Avatar
Mercedes S350
Hi there - thanks...I'm in the UK too so its a RHD car...the noise appears to come from behind the dash...maybe the center area...its quite odd..
Old Feb 25, 2020 | 01:00 PM
roviw1's Avatar
Noises can be funny to pinpoint, mine seemed to be from just the other side of the centre console and down low. I did not have an invoice for the work but on the CL my friends invoice was maybe £500 or so fully fitted by main dealer .
Mine was odd, it was not all the time, it happened a few times over a few weeks, then gradually more often, I did take it to the dealer and we went out on a 10 mile drive but no noise at all, typical !.
I then suggested that the following week they may keep the car the whole week and try it several times.
On the morning I was taking it in to them it was making the noise, when I get there I asked a technician to come out to the car without me turning the engine off, I managed to hear the noise while just driving forward very slowly in the car park..
I was going to suggest the damper as my friend thought it may be that as he had it a few years earlier on his CL, my friend had initially thought it was a transmission issue.
As soon as the technician heard it he said that was what he thought it was ( without me suggesting it ).
They fitted a new one and instant silence .
Best of luck
Old Feb 26, 2020 | 08:03 AM
1bad540's Avatar
s550 Diamond white amg pano
I had this same issue in the cold and in stop and go traffic was terrible. I took a video and showed the dealer the brake booster had a pinhole in it and was changed under warty.
Old Dec 15, 2021 | 04:41 AM
benzw205's Avatar
benzw205
Not noisy anymore after changing the pads once. The stealer changed them, so I guess that they use original MB parts ?
Old Dec 27, 2022 | 03:04 PM
cotmfk's Avatar
On the shoulder
Bumping an old thread - does anyone have the part number for this? FCPEuro doesn't seem to carry it.
Edit: Two parts found:
Brake master cylinder:
212-430-06-01
Brake Booster:
212-430-31-30
Old Dec 27, 2022 | 04:42 PM
konigstiger's Avatar
'71 Pinto
Comparison shop: https://mbworld.org/forums/s-class-w...ts-online.html
