S-Class (W222) 2014-2020
Blue or Red Antifreeze?!
Old 10-11-2019, 12:43 PM
tkelley.EClass's Avatar
2014 E350 Sport (sold), 2015 S550 Sport (sold), 2018 S560 Sport (sold), 2018 GLE43, 2014 E550
I got the old "coolant level low" notice today. Went MB to buy my $30 bottle and the lady said "yeah, think its the red one". Can someone confirm this is the right product? Pic attached here.
Old 10-11-2019, 02:01 PM
konigstiger's Avatar
Received 4,441 Likes on 3,153 Posts
'71 Pinto
BQ1030005 = 325.5
Should be blue BQ1030004 (0009890125)
https://bevo.mercedes-benz.com/bevol..._en.html#close
https://bevo.mercedes-benz.com/bevolisten/325.5_en.html
File Type: pdf
Old 10-11-2019, 02:28 PM
Thanks! Should I be doing a fluid swap or is a top off okay? That is once I get the right product. How does the dealership sell me the wrong stuff?!
Old 10-11-2019, 03:01 PM
1bad540's Avatar
s550 Diamond white amg pano
open the cap man.... obviously when its not hot. Thats bc people at the dealers arent into cars and havent got a clue.
Old 10-11-2019, 03:15 PM
Gotcha, wasnt sure when a full fluid swap was advised. Im at 35k miles. I've done brakes and oil changes so I should be able to add antifreeze :-D
Old 10-11-2019, 04:11 PM
'71 Pinto
Top off, posted sheet to show coolant specs.
Old 10-11-2019, 08:47 PM
Copy, thank you. Will also be swapping my aux battery this weekend as well. I see you have posted instructions for this process on various posts without the cheeky "search the forum first". Appreciate it.
Old 10-11-2019, 10:12 PM
77Tony's Avatar
2015 S550
This is what I've been using on all of my aluminum block engines for the last 100 years: (IIRC Porsche & MB both rebrand thiese products, add a dye and sells to the consumer for $$$. Be sure to mix with distlilled water (found at Walmart, etc., for cheap$) Note: Add frequency to the mix...change your antifreeze and brake fluid (flush) at the same time...(every two years).Your head gaskets, brake lines & components will love you 4-eva ! T :https://www.napaonline.com/en/p/ZRXZ...oaAksPEALw_wcB T
Quick Reply: Blue or Red Antifreeze?!
