S-Class (W222) 2014-2020
Rear rotor and brake pad replacement
Old 08-24-2020, 07:14 PM
E. BAUTISTA's Avatar
Mercedes benz s450
Can anybody help me I have a Mercedes Benz s450 and I need to turn off the rear electronic brake so I could change out the rotors and brake pads thank you nothing on YouTube or anything else all I can find is 2017's classes and lower nothing for the new facelift model.
Old 08-24-2020, 07:16 PM
phillyreem's Avatar
GL450
The 2017 you tube video will work. Same system
Old 08-24-2020, 08:47 PM
Mercedes benz s450
completely different system completely different steering wheel I don't have the okay button I put up a picture so people could see the difference nothing from 2017 will work and under Mercedes wants an hour of Labor just to tell me a 3-minute process which is crazy
chassis (08-24-2020)
Old 08-24-2020, 09:23 PM
chassis's Avatar
Received 3,971 Likes on 3,121 Posts
2017 GLE350 4MATIC
@E. BAUTISTA What year is your vehicle and the VIN? The W222 procedure according to WIS is the same as W166, W205 and several other vehicles. The steering wheel button sequences include an "OK" button. Using your VIN I can see if the procedure is in my version of WIS.
Old 08-24-2020, 09:36 PM
Mercedes benz s450
Originally Posted by chassis
@E. BAUTISTA What year is your vehicle?
mercedes benz s450 2018 no ok button all the previous videos for 2017 and under will tell you to hold ok button and phone button for 1.5 seconds and release and I would be able to release electronic brake thx for your help. Tried holding the home button and black square but nothing read the owner's manual nothing on brakes
Old 08-24-2020, 09:42 PM
Mercedes benz s450
mercedes benz s450 2018 vin WDDUG6GB2JA348178 thx you
Old 08-24-2020, 10:52 PM
chassis's Avatar
2017 GLE350 4MATIC
@E. BAUTISTA The same WIS procedure comes up when your VIN is entered. WIS 42.10-P-1700-02W. This includes an "OK" button. When you change multifunction display pages, what button do you use to accept changes or make entries?
On page 246 of the S-Class owners' manual, it says to "confirm the selection", "press the left-hand side of Touch Control (2)". What happens when you use the left hand side of touch control 2 as the OK button? See your owner's manual for a diagram, or here: https://www.mbusa.com/en/owners/manuals
Old 08-24-2020, 11:09 PM
Mercedes benz s450
thank you very much in the am I'm going to try the left hand side control (2) button and the phone button and see if that works god speed
chassis (08-25-2020)
Old 08-25-2020, 10:33 AM
MikeAtLincoln's Avatar
2018 S450
This procedure worked for me. I have a 2018 S450.
Close doors
With foot off the brake, press start button one time
Left side of wheel:
Use touchpad to select odometer display
While holding "Home Button down wait for start of memu display and press the touchpad next to the home button.
The service menu should now be visable.
The service menu has the option of releasing the rear brakes.
Quick Reply: Rear rotor and brake pad replacement
