An install and a repair that I’d like to do myself on 2015 s550
I recently hit a bad pothole going 80+ on the interstate and destroyed the sidewall of the runflat, so maybe it damaged the strut as well. But maybe the fact that the only tow shop open at nearly 11pm just happened to have a used tire that was a slightly different size than the oem tires has caused them to see a different gap between fender and tire on that side and assume a leak. Either way, I’m not letting them replace it, I will either do it myself or take it to an indy shop. The car was not obviously unlevel when I dropped it off. I have a new set of wheels and tires ready to install as soon as the car comes home. Once the off-sized tire is replaced, how do I test the strut at home? Is it as simple as parking it, measuring ground to fender and then re-measuring after some time has passed?
If it does need to be changed, will I need a diagnostic tool to bleed the air? I have only been able to find a video on changing the rear struts and it did not look like something I want to try, partly because it said I needed to have a diagnostic tool to bleed and to repressurize the system if I remember right. Is the front strut a quick “unbolt and swap” or will I have to buy equipment to bleed and refill the air? Can anyone link a video to show front-strut replacement on the w222 (assuming they are all the same as the 2015)?
The install question is regarding the Meisterschaft GTHaus exhaust with remote controlled valves. I’ll take delivery on that next week and was curious if anyone here had done the electrical connections. Does this require drilling through the floor into the cabin or is there electrical available underneath the car and if so, which wires are people tying into?
Sorry for the length of the post and thanks for any help you can provide.
Typically, the earliest signs that an air strut is failing is before a cold start when you're greeted by a vehicle that has one corner significantly lower than the rest. The car will level once started, but if the strut is consistently low or collapsed after setting for several hours, then you should replace the strut. Besides affecting handling, driving with a failed/failing strut forces the Airmatic compressor to run longer and more often, which diminishes its life.
BTW, I'm an advocate of replacing Airmatic struts in pairs if possible. Due to cost, people tend to replace them individually, but experience has taught me that the handling dynamics with a new strut on one side and an old strut on the other is quite noticeable. Replacing the front set and rear set at different intervals is fine, but IMHO, I would not replace just one strut on an axle. If you're an enthusiastic driver like me, you'll notice it.
So you didn’t use the diagnostic tool shown in the video to bleed or repressurize the system?
