S-Class (W222) 2014-2020
Best place to get replacement AMG 20" wheel?
Old Sep 23, 2020 | 05:02 PM
RSouthern's Avatar
S550
So I hit a pothole here in San Jose cracking the rear wheel. I had the wheel welded and repaired and it looks ok, but I'm nervous about the long term durability of the weld. I've been searching online (eBay mostly) looking for a replacement wheel, but all that are listed <$1000 are re-manufactured and when checking with the sellers, many are either bent or cracked and repaired, so no different than what I have already on the car. Any suggestions on reliable and trustworthy places to look in San Jose or nearby or online that sell the 20" multispoke AMG wheels (2015 S550)? I don't want to get a knockoff, OEM only.
I'm also concerned about matching the finish of the machined surface on the wheel face and making sure that the painted interior color matches the rest of the wheels. It looks like a gray, but I've seen listings saying gray and charcoal as colors and am not sure which is correct. The OEM part number is a2224010500 for the rear wheel. I've seen plenty of new wheels online, but not much in the way of used in good condition. What do people do with their OEM wheels when they put custom wheels on their W222s in the Bay Area?
thanks for your thoughts
-Richard
Old Sep 23, 2020 | 06:53 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
thanks for your thoughts -Richard
Richard, Do you have an an auto wrecking/recycling yard near you? Many of them have links to check other yards for what you need.
Old Sep 24, 2020 | 06:34 AM
e55phil's Avatar
2021 e All Terrain, 2001 e55
I have 20 inch wheels with new tires. I took them off to run 19 inch because i hit a pothole. I think one of the four are unrepairable. if you are interested PM me. I want to sell all 4. The tires are Contanetal DWS, Honestly I forget if they are run flats. I have the TPMSs They are at the tire store and I can go Monday to look I would sell all 4 for $2100 not including freight Here is a photo from a year ago.
Also If I am not allowed to post this here for some reason I am sorry and I can take it down.
Old Sep 24, 2020 | 10:39 AM
Streamliner's Avatar
This is a great source. I’ve used them: https://www.alloywheelsdirect.net/me...eelbase_alloys
Old Sep 24, 2020 | 11:59 AM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Every OEM wheel has what is called a "Hollander" number that is the exact match to the wheel you have. Any tire shop should be able to look up the number for your wheel. I have had great luck searching on Ebay using this number to find the exact wheel I needed in the right color.
I will say though that I have also had wheels repaired and trued and they have worked fine after the repair.
Old Sep 25, 2020 | 12:34 AM
cetialpha5's Avatar
You're allowed to post for sale ads. There's actually a separate section for posting sale items in the marketplace. Sometimes people post in both forums. Anyway, what do you mean by unrepairable? Usually if there's a dent, they can bang it out, if it's cracked, they can weld it and then bank out the dent. Unrepairable is usually a chunk/piece of the rim missing. Also post the MB part number on the back of the rim. That will usually cross reference to a hollander number.
Old Sep 25, 2020 | 11:48 PM
RSouthern's Avatar
S550
Thanks for the various suggestions. Not looking to buy 4 new wheels, 3 of the 4 are in pretty good shape, so I'm only after the 1 rear wheel.
That's a good suggestion to check the local wrecking yards, or going with the new wheel purchase from that dealer as it looks like the do sell 1 or the whole set.
I was hoping to find someone in San Jose who took off their wheels for whatever reason and was ok with selling 1, or the whole set for cheap and then I'd do the same... don't need yet another stack of wheels in the garage, already have 4 Jeep Wrangler 34s in there, starting to run out of room!
Appreciate the pointers.
Old Sep 27, 2020 | 07:30 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Like these? https://mbworld.org/forums/market/767113
Old Oct 5, 2020 | 03:02 PM
RSouthern's Avatar
S550
Originally Posted by Tom in Austin
yep, just like those, except if they were in San Jose, Ca
thanks for the link! I'll just keep watching and keep my OCD in check regarding the weld repair.
-Richard
