Trans Flush or Service
As far as doing the remove pan and change filter I have done it and its pretty straight forward. You can buy a kit on Ebay for your trans that included filter, pan bolts, and the correct Ravnol fluid and standoff. All that remains is the filler adapter for a few dollars and a scan tool to show trans fluid temp.
I would say one thing though. I think you could get by with no scan tool if you took the time to measure exactly how much fluid came out and put the exact amount new fluid into the car.
They just put in what was removed as Katie suggests. Actually, tho, you can use a temp scan gun which are pretty cheap now. And they’re nice to have around for checking coolant temps, a/c vents, a/c leaks, etc.
My dealer did this to my E320 back in the day. Blew out the transmission seals & destroyed transmission by causing a leak. $6000 to repair...
Drop the pan & service the old fashioned way.
Mercedes spells out a transmission fluid change interval, so yes it should be done.
The service includes a filter change, which requires the pan to be dropped. The WIS procedure also calls for the torque converter to be drained, an important step. This service is not a "flush".
A "flush" is a pressurized oil change that replaces fluid in the cooler lines and cooler. This is rare because of extra time and effort, and does not appear to be called for in WIS.
You can buy WIS on ebay for around 8 to 19 dollars.
Here is an example of the service kit you can buy to do the job. Missing is the filler adapter.
http://www.blauparts.com/repair-part...caAi56EALw_wcB
and here is the filler adapter
https://www.shell.us/business-custom...r-locator.html
. Now I guess I have an extra-clean transmission given that the torque converter can’t be completely drained. And yeah the dealer replaced spark plugs at 54K miles included with prepaid service. Since then I ended up replacing two dead ignition coils at home.
The hardest part of the W222 7G is dropping the contraption which holds up the exhaust pipes. Otherwise, you cannot replace a external-torx screw (single-use) when you drop the pan. They are very large bolts holding up the exhaust. Since then I obtained at a complete set of Williams impact sockets which which extend to even the most massive sized bolts.
Katie
Katie
Bravo to anyone here doing their own work. The cars are not that difficult to take care of.
