Hissing noise from speaker behind front passenger seat
I have the Burmester 3D system. Anyone have any experience with this? Given that it should be silent, I’m wondering whether there is a electrical harness problem
I also have the Burmester 3-D system. I didn’t realize there were speakers in the backs of the front seats. I thought they were vents for the cooled seats. My system does not make the hissing noise.
I immediately found the leak when I took the seat panel off. Purple hose at the bottom. The pneumatic hose cracked at the fitting because the nylon? Hose was clearly too short and under constant tension. I tried to splice a PVC hose with brass barbed fitting but the 3/16 inch ID brass barb splicer was too large and split the nylon hose as the hose had minimal flexibility. I didn’t want to try a 1/8 inch ID brass barb splicer at the risk of increasing the resistance and demand on the pump (Poiseulle’s equation) as this being the widest hose may be directly coming out of the pump.. I was thinking of buying a push-snap pneumatic fittingly I can find the matching size.
Does anyone know where I can buy this purple size hose or buy pneumatic hoses which are not only even sized (6, 8, 10mm)? It doesn’t have to be purple obviously. I was having trouble finding a nylon 7mm. It is larger than all the other pneumatic hoses in the back of the seat panel which appear to be 6mm OD. This purple one is somewhere in the 6.6 to 6.9mm OD range depending on where I measure. Maybe it’s a 7mm? I could not find a online site selling 7mm nylon tubing.
New problem. I can’t change my seat bolster settings. There is no leak in the air bladders. However, I cannot return them to original settings. I cannot firm up, nor can I deflate and soften from the existing settings on the shoulder, lumbar or side cushions. They remain nice and inflated but will not change from their existing settings. Nor can I activate the massage function. This issue existed before my tube leak but I wrote them off to the leaking tube which has definitely been repaired.
Anyone have an idea? Or does it need some kind of Mercedes STAR system software reset?
