S-Class (W222) 2014-2020
Internal Settings are Turning Themselves Off
Old Jul 27, 2021 | 06:22 PM
tkelley.EClass's Avatar
2014 E350 Sport (sold), 2015 S550 Sport (sold), 2018 S560 Sport (sold), 2018 GLE43, 2014 E550
I have a 2018 S560 and keep having to turn certain options back on regularly. For instance, I set my dynamic seats to level 2, turn air ionization on, fragrance boost on low, and ambient lighting to 100%. A week or two goes by and all those things change back to factory default. Brought it to the dealer, they did a software update, and sent me on my way. Unfortunately, no change... Has anyone else experienced this? Any fix?
Old Jul 27, 2021 | 09:25 PM
Originally Posted by Plutoe
your foolish go back and sit on the service manager lap until rersolved
Yes, I'll be going back. I of course needed the car back for a few days before I was able to determined that their "fix" did not work.
Old Jul 27, 2021 | 11:22 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Any chance you are using a different key. Settings stored on Key 1 and sometimes you use Key 2?
Old Jul 27, 2021 | 11:25 PM
Other key is locked up in the safe so no dice. Good to know though!
Old Jul 28, 2021 | 01:42 AM
superswiss's Avatar
2019 C63CS
Are you using the User Profiles and have them synching to the server? Typically when this happens it's an outdated user profile that syncs to the car and overrides the current settings. Adjust your settings to your liking and then manually export the profiles to the server. I don't know about mBrace in the 2018, but they messed around with the personalization service in Mercedes me connect for MY2019+ and rolled out a new version. When they did that my profile on the server was completely out of sync and I had to do the export to avoid old settings from coming back.
Old Jul 28, 2021 | 07:59 AM
DaveW68's Avatar
Veteran: Army
2015 S550
Have your starter and accessory batteries load tested. Strange stuff like this often happens when the batteries are nearing end of life.
Old Jul 28, 2021 | 05:45 PM
THANK YOU! I'm going to check this out this week and report back.
Old Jul 28, 2021 | 05:46 PM
Great tip, hope this is not the case with 17k miles but its worth a shot.
Old Jul 28, 2021 | 06:10 PM
DaveW68's Avatar
Veteran: Army
2015 S550
That could be exactly the issue. It's obvious your car doesn't get driven a lot so the batteries are likely never getting a full charge when you do drive it. Also, sitting for extended periods can also cause them to lose charge and wear out.
Your dealer, an indy, or even a place like AutoZone can do a load charge for you to check the condition of your batteries.
Old Jul 29, 2021 | 08:53 AM
Thats a great point, thank you. Going to give this a shot as well.
