S-Class (W222) 2014-2020
2015 W222 bumpy ride on rough roads
Old 08-18-2021, 07:07 PM
danmiles68's Avatar
2019 S560 4Matic
Hello,
I bought a preowned 2015 S550 4Matic 30 days ago, which replaced my 2014 CLS550. The car only has 38k miles on it, but I have noticed that the car has a very bumpy ride when going over potholes or just on rough pavement. It came with 19" AMG wheels and run-flat tires. I have never had run-flat tires, but many have complained in other forums about the ride from run-flat tires, but I can't imagine that they would cause such a noisy and bumpy ride over potholes. Any thoughts on what issues might be going on? The vehicle doesn't drop at any wheel when sitting, so I assume there is no leak in the AirMatic system, but I could be wrong.
Thanks in advance!
Old 08-18-2021, 09:00 PM
Tom in Austin's Avatar
2016 S550, 2015 Honda Civic Hybrid
Congrats on the new S and welcome to the W222 forum. A couple of obvious things to start with:
  1. Is the suspension in Sport or Comfort mode?
  2. What is the tire pressure? (Recommended settings are on the fuel filler door, one for regular driving, and a higher one for "extra load")
  3. How old are the tires, generally ride comfort declines as tires age and approach the end of tread life. The brand and model of tires are factors too as many on here have found some are much stiffer riding than others
Everyone's standards/expectations are different, but an S is capable of a very nice ride on good, fair or slightly bumpy pavement. On truly rough roads, over railroad tracks, etc. an S can jolt and shake hard at times, at least according to my 'assometer'.
walterk55 (08-19-2021)
Old 08-18-2021, 09:21 PM
danmiles68's Avatar
2019 S560 4Matic
Hi Tom, thanks for the reply. It doesn’t matter if the car is in comfort mode or sport mode, the ride is still the same. Tire pressure is a couple of psi‘s below normal but I wouldn’t think that would make a big difference. Tires are Pirelli Cinturato P7 and appear to be relatively new with very good tread depth.
Old 08-18-2021, 10:06 PM
emilner's Avatar
S560
Based on what you said it sounds like a suspension (possibly airmatic) issue. There is a noticeable difference from sport to comfort. Comfort should feel smooth even on older RFTs.
Old 08-18-2021, 10:31 PM
danmiles68's Avatar
2019 S560 4Matic
I guess I need to take it to the dealer, I just hate getting hammered by their prices. I need to find a good Indie shop that knows these cars.
Old 08-18-2021, 10:36 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
Runflats are likely responsible for your bumpy ride. Unless your car is sitting very low, its unlikely the Airmatic is the problem; their only typical problem is deflation. As for the noise, that may be specific to your tire, or you have have been expecting more quietness than the S-class actually delivers (this was an issue for me as well).
Streamliner (08-19-2021)
Old 08-18-2021, 10:39 PM
emilner's Avatar
S560
A runflat will not cause a "bumpy" ride. They just get harsh over jolts. If you are driving and the ride is up and down bumpy that has nothing to do with tires. I have heard of issues with the suspension where it firms up dramatically...
Old 08-18-2021, 10:47 PM
cfmistry's Avatar
He stated he had a "very bumpy ride when going over potholes or just on rough pavement". In my humble and lowly opinion, that is likely from the RFs. I suppose it could not hurt to have the Airmatic system checked, but I know where I would put my money!
Old 08-18-2021, 11:13 PM
danmiles68's Avatar
2019 S560 4Matic
It’s almost like riding in the back of a beat up Uber or taxi cab when I drive over bumps in the road. Even my CLS was smoother although it was a sporty and rougher ride than previous E and S class cars I have had.
Old 08-18-2021, 11:16 PM
danmiles68's Avatar
2019 S560 4Matic
I guess I will look at replacing the tires. Even if the AirMatic needs some work, I have not heard of anyone who likes runflat tires.
Old 08-18-2021, 11:21 PM
SW20S's Avatar
Received 2,885 Likes on 1,859 Posts
2024 S580
When you say the tires are a few PSI below normal, what PSI are they cold exactly?
I have non runflats and I run mine at 32 PSI Cold and it rides great on AMG 19s.
Old 08-19-2021, 12:06 AM
Donnymac's Avatar
63 Falcon vert
Road surface imperfections will be magnified with a RFT because of the rigid sidewall design. A NRFT will deliver the opposite result due to a designed flexible sidewall.
The two do not ride the same.
Old 08-19-2021, 08:57 AM
danmiles68's Avatar
2019 S560 4Matic
The pressure is between 35-36 psi cold.
Old 08-19-2021, 10:07 AM
Normal tire pressure spec for my car is 33 cold for 19 or 20 inch tires
Old 08-19-2021, 10:16 AM
Streamliner's Avatar
Received 3,765 Likes on 2,150 Posts
2020 S560 Sedan, 2019 SL450, 2019 E450 Luxury Trim Wagon, '24 BMW I7 on order...
For those of us that are highly critical of ride quality, run flat tires are the KISS OF DEATH! Admittedly, RFT have improved over the years, but when switching to a non-run flat, very cushy, all season tire, the difference, at least to me is DAY AND NIGHT! I run 18” wheels with Bridgestone QuietTrack tires and MBC on my 2020 S560. I believe my car is the best riding, most quiet sedan this side of a new Rolls-Royce. I carry a W221 compact spare in my trunk. Good luck to you.
Old 08-19-2021, 10:49 AM
DaveW68's Avatar
Location: Land of Political Criminals and Urban Shootings
2015 S550
I concur with others here that RFT's suck and ride like crap. They are also prone to having the tread split from the sidewall when hitting potholes or large bumps in the road. Basically, they're garbage and don't belong on such fine cars.
I've got the AMG 20" wheels and swapped out to these tires in the spring. They've been fantastic and ride super quiet and smooth, even on 20's. They'll also save you a ton of money over the Michelin's and are every bit as good.
No need for a spare in your car when not having RFT's. Blow-outs with regular tires are extremely rare....kinda like the odds of getting hit by lightning. And slow leaks from nails or whatnot can easily be repaired before the tires get too low. But if you're on a trip and notice a faster leak, you can always have this in your trunk to take care of those instances.
Old 08-19-2021, 11:00 AM
Originally Posted by DaveW68
………..No need for a spare in your car when not having RFT's. Blow-outs with regular tires are extremely rare....kinda like the odds of getting hit by lightning. And slow leaks from nails or whatnot can easily be repaired before the tires get too low. But if you're on a trip and notice a faster leak, you can always have this in your trunk to take care of those instances.
Unless, of course, you happen to hit a road hazard that shreds the tire and/or destroys the wheel. As a former Boy Scout, I always believe in being prepared.
Donnymac (08-19-2021)
Old 08-19-2021, 11:12 AM
DaveW68's Avatar
2015 S550
WE ARE PREPARED!!
The trunks in these cars are smallish for a large car. And yours is even smaller with the rear sub. The spare cuts in to the space too much and is completely unnecessary. In 37 years of driving, I've never had a blow-out and I bet over 95% of all drivers on the road have never had one either. But if you do get struck by lightning and have one, that's what AAA, your car's insurance, or your car warranty is for to cover a tow. And please don't reply about a long weekend trip or tire repair shops being closed on Sundays. Those donuts are only good for 50 miles and won't help you finish your trip without a stopover anyway.
Old 08-19-2021, 12:34 PM
SW20S's Avatar
2024 S580
I would lower it to 32 and see what you think.
Old 08-19-2021, 01:05 PM
WE ARE PREPARED!!
TRUE STORY: Around 1998 or so, I was driving my 1997 Lexus LS400 home from my office in the L.A. area to my home in Orange County, on the infamous 405 San Diego Freeway, passing through Long Beach. It was later rush hour, around 6:30pm or so, dark outside and traffic was heavy, but moving fast. I was in the fast lane, doing around 65 or 70mph, when my right front tire hit something and the tire blew out. I managed to control the car and get to the right shoulder, where I called AAA. Before they came, a Metro tow truck, pulled up behind me, lights ablaze. The driver jacked up the car, put my FULL SIZE, MATCHING spare on (Thank you, Lexus!), put my chewed up wheel and SHREDDED, nearly new Michelin tire in the trunk and I was home for dinner. I never knew what I had hit, but the tire was destroyed, and the alloy wheel needed to be replaced.
Had I been driving most any car, with most any type of tires and no spare, I would have been riding in the cab of the tow truck, leaving my car overnight somewhere and taking a taxi home. Now, just imagine this exact same scenario, but the car is full of your wife & kids and you are not in a metro area. Not good.
Old 08-19-2021, 02:39 PM
SW20S's Avatar
2024 S580
But that was 23 years ago and hasnt happened since. Its a hassle/benefit analysis as to how much you want to sacrifice to prepare for something that might happen once in a persons entire life...
DaveW68 (08-19-2021)
Old 08-19-2021, 02:46 PM
badq45t's Avatar
2016 S550e, 2005 Nissan Xterra 4x4, 1984 300ZX
I would give up the one incident for giving up all my trunk space. My S550e has even less than standard so when I switch I will add a pump and some fix-a-flat (last resort) and my AAA Premium subscription will cover me trom there. To the poster, the S Class shouldn't be a bad ride, I haven't heard good things about the Pirelli's and you should go to America's/Discount Tire or a place that will give you a trade-in credit since you mentioned that the tires are nearly new and get a set of non-run flats.
Old 08-19-2021, 02:51 PM
You make a good point. We all have choices to make. I choose to carry that spare. It gives me peace of mind and with just my wife and I, we have never needed more trunk space, so I really don’t feel as though I am giving anything up.
Old 08-19-2021, 03:54 PM
Donnymac's Avatar
63 Falcon vert
One size does not fit all. What is sacrifice to one is insurance to another. Also depends on where and how you drive. My S has a trunk with a backpack, bedroll, rifles, cutters plus a satellite phone and it survives the car wash just fine. AAA is of no use to me and I need a spare. I get the RFT concept but I’ll take the insurance.
Old 08-19-2021, 03:58 PM
DaveW68's Avatar
2015 S550
You and your wife must not be golfers. I have the reclining rear seats like you, so I too have the notch in the front of the trunk. I also don't have the rear sub. But my golf clubs still barely fit on an angle with shoving the woods and irons into that front notch. With a donut spare, the only clubs that would fit would be little kids clubs.
I choose to carry golf clubs at all times. It gives me peace of mind.
Quick Reply: 2015 W222 bumpy ride on rough roads
