S-Class (W222) 2014-2020
Swap 19's for 20's AMG Question Before Purchase
Old 11-25-2021, 08:44 AM
dpayne7571's Avatar
2013 S550, 2009 E320, 2013 ML350 Bluetec
I've been searching for awhile for the perfect CPO S560 and I found one close to me, problem is it has the 19in AMG wheels and I want the 20in wheels. Is the bolt pattern the same and I do not want run flats so I'm just making sure I change change out and does anyone know how much it will cost outside the car purchase to buy another set of rims and tires...
Thanks!
David
Old 11-25-2021, 09:05 AM
Tom in Austin's Avatar
2016 S550, 2015 Honda Civic Hybrid
Congrats on the new S! Post a pic, love to see it. There are lots of wheel sets here on the MBWorld classifieds, and there are companies that offer a big selection of used/refurbished wheels like Santa Anna Wheel in Anaheim, CA. New wheels from a dealer could be wildly expensive, but you can often find "take offs" where someone upgraded wheels and tires on a fairly new car.
Nearly all Mercedes cars use a 5 x 112 mm bolt pattern so that's not an issue. You'll want to check the "ET" measurement, also referred to as "offset" ... your car prob has 38 mm ET, and I think most W222 AMG wheels are 38, but you'll want to verify before you buy.
hyperion667 (11-25-2021)
Old 11-25-2021, 09:28 AM
Sumfuncomet's Avatar
2020 S560 sedan, 2018 Volvo v90 Cross Country
19 inch ride better especially non RFT!
Old 11-25-2021, 10:03 AM
dpayne7571's Avatar
Nearly all Mercedes cars use a 5 x 112 mm bolt pattern so that's not an issue. You'll want to check the "ET" measurement, also referred to as "offset" ... your car prob has 43 mm ET, and I think most W222 AMG wheels are 43, but you'll want to verify before you buy.
Thanks, but I haven’t bought the car yet, making sure I can swap out and it seems like I can. Gotta find take offs now. 😊
This 560 is a big difference from my 2013!
Old 11-25-2021, 10:15 AM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
If I could do it all over again I would go 19". I have the 20" AMG wheels; all 4 have been bent multiple times and repaired. MB wheels are known for bending.
Old 11-25-2021, 10:34 AM
dpayne7571's Avatar
Did you have run flats?
Old 11-25-2021, 10:53 AM
cfmistry's Avatar
No, I had Continental DWS 05 and now have Michelin Pilot AS4s. I would have appreciated the soft ride and lack of pothole damage from 19”s. And I’m only 36.
Old 11-25-2021, 12:04 PM
PNBLWZD's Avatar
2016 S550
I would try it with the 19”’ for a while and see how you like it. My car came with the 20” AMG multispoke on pirelli runflats, and although they look good and it’s not a bad ride I know it could be smoother.
Old 11-25-2021, 04:41 PM
This has been an often discussed issue on many posts. I had the Michelin runflats on the car, from new. The Firestone Indy 500s are so profoundly different it is amazing. Gone is the thump/bang over railroad tracks or thwack over expansion joints. I run Nokians on equal sized 19" for the winter, excellent tire as well, a little bit loud but acceptable. Here in Maine most people run dedicated snows on other set of wheels.
Quick Reply: Swap 19's for 20's AMG Question Before Purchase
