S-Class (W222) 2014-2020
2 tanks of gas, and a trip to Florida. Happy with the mileage 😃
Old Dec 12, 2022 | 06:12 PM
will_atl's Avatar
2020 S450 4Matic, 2022 GLS450 4Matic, 2015 C300
Old Dec 12, 2022 | 08:06 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
That's amazing for a 4,700 lb car traveling at (or above?) interstate highway speeds!
Old Dec 12, 2022 | 08:08 PM
will_atl's Avatar
Yes officer, of course!
Old Dec 12, 2022 | 08:43 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
It took me 1,5 tank of diesel in my Audi A8 TDI.
Old Dec 12, 2022 | 09:03 PM
JohnLane's Avatar
222 S-65
Averaging 60mph over a thousand miles implies OP was not holding up traffic.
Respectable mileage that is. I lack self restraint and fuel economy suffers for it.
Old Dec 12, 2022 | 09:10 PM
will_atl's Avatar
I used Distronic for all but 3 hours of the total driving, normally about 5mph over.
I use Distronic daily in my commute.
on a 5 hour stretch, with a couple of bio breaks, it makes it very easy, if not a little mindless. My wife drove for a couple of hours on the way home and she does use Distonic at all, even in her GLS!
Old Dec 12, 2022 | 10:05 PM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by will_atl
Can't beat that with a stick! Well done and thanks for the report. W222 S450 is one of the best preowned MBs on the market today.
Old Dec 12, 2022 | 10:10 PM
Donnymac's Avatar
63 Falcon vert
Good points. That speed probably included 2 gas stops and depending on pax, maybe 3 or 4 pee breaks.
Old Dec 13, 2022 | 02:09 AM
BenzV12's Avatar
W212 FL
Average speed is not too low but still not bad for a twin turbo engine
Old Dec 13, 2022 | 12:32 PM
Sean._.S's Avatar
S550
Sweet! I average about 27 from FL to NC in my S550. Amazed at the mileage these cars can achieve above highway speeds
Old Dec 13, 2022 | 02:10 PM
Sactownmb's Avatar
MY 18 S450V RWD Diamond White
Very nice. 1020 miles at 61mph avg. while delivering 28.3 mpg in a full sized lux. car. Outstanding numbers. Thanks for sharing.
Old Dec 13, 2022 | 02:12 PM
will_atl's Avatar
My pleasure, it was a family of four with luggage for the weekend (two adults and two teenagers).
Old Dec 13, 2022 | 03:26 PM
MBNUT1's Avatar
2010 E350 4Matic
This is in line with the EPA highway mileage. They must have gotten less conservative with the ratings over the years as I can easily beat the rating on my car.
Old Dec 13, 2022 | 07:01 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
I will see you S450 and raise you an S-600
Old Dec 14, 2022 | 08:31 PM
MBNUT1's Avatar
2010 E350 4Matic
That is similar to the differential I get with my car relative to the EPA rating. You did have 30 degrees of temperature delta working in your favor relative to the OP.
Old Dec 14, 2022 | 09:14 PM
will_atl's Avatar
Wow, I wouldn’t have expected an S600 to do so well! Great job, do you use distronic (like me) or actually rive your car yourself?
Old Dec 15, 2022 | 02:45 PM
Top Answer: 1
S600
I mostly do not use distronic.
Old Dec 16, 2022 | 10:51 AM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
I find that really interesting that the 450 doesn't do much better than the 560. Here's mine from a trip, this was in the mountains for 100 miles of it and cruise set to 80.
Old Dec 16, 2022 | 11:00 AM
will_atl's Avatar
I’m thinking that the engine in the 450 has to work harder to haul around these monsters!
Old Dec 16, 2022 | 12:18 PM
Top Answer: 1
S600
Below a certain speed (bear with me) and at constant speed the fuel consumption is basically rolling resistance plus (?minus?) what ever fuel is used to turn the motor over). So, it is no wonder that the 6cylinder, the 8 cylinder and the 12 cylinder are so close--all of the engines are loafing around at 7 HP.
Above that speed you add in a quadratic consumption of fuel based on aerodynamics.
My measurements indicate that for the W222, that the optimal speed is in the mid-high 60-MPH realm. 65-67 MPH is optimal speed; you can't get any more MPH than at optimal speed (unless you turn the engine off and coast down hill).
The W222 has better aerodynamics that a Prius--especially at higher speeds.
Old Dec 17, 2022 | 09:34 PM
2012 merc amg's Avatar
2018 S560
I generally average around 29 mpg in my s560 on trips going 72 mph. If you put the torque and hp gauges on the center screen you can see how little hp and torque it takes to keep the car moving once up to highway speeds. The car is quite aerodynamic and the power train fair efficient.
Old Sep 27, 2023 | 08:17 PM
will_atl's Avatar
One tank of gas and a trip from Atlanta to Florida, just me and one of my sons, the rest of the family are on their way with Delta. Great mileage today (30.1 mpg!)
