S-Class (W222) 2014-2020
W222 AMG S65 lithium battery change instructions
Old 06-28-2023, 09:38 AM
GGsAMG's Avatar
2015 S65 AMG
Does anyone know the procedure to change out a lithium battery on a 2015 S65 AMG? It’s a special battery with a lot of connectors. I’ve changed out a lot of batteries in my life but this one is much different and I’m sure there has to be a process order to disconnect it and install the new one.
Old 06-28-2023, 11:04 AM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
First you have to find the new battery. If you already have the battery there is no special order to unplugging everything. I would start with the positive terminal, then negative, then the connectors. Benz Ninja has a service where he can program the car not to look for this Li Ion battery and then you can just use a comparable AGM battery for a fraction of the cost of a new Li Ion battery. The only reason MB used a Li Ion battery on the S65/63 variants is for weight savings.
BenzNinja (06-28-2023)
Old 06-28-2023, 11:12 AM
GGsAMG's Avatar
2015 S65 AMG
Great to know! Thank you!!
Old 06-28-2023, 07:00 PM
W205C43PFL's Avatar
Received 2,650 Likes on 2,254 Posts
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Does one type last longer than the other though?
Old 06-28-2023, 07:07 PM
vincheung's Avatar
S63, GLE580, Monster 1100S
@w205, the benz lithium is said to last up to 10 years or so, in my experience AGMs can go 7+.
Problem is right now sourcing the lithium car battery for the S63/65 and GTs are almost impossible since it’s back ordered with no fulfillment time frame (gray market new old stock is grossly inflated). Fortunately for us, benzninja can code in/out the use of an AGM if and when your lithium decides to throw in the towel.
Old 06-28-2023, 07:21 PM
W205C43PFL's Avatar
I see, understood.
Old 06-28-2023, 11:41 PM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
It's important to disconnect the negative side of the battery first, otherwise you can cause an electrical short if the positive is removed first. Positive first when reinstalling the cables.
Old 06-30-2023, 12:38 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Thumbs up
2014, I'm on 9 Years.... No Issues. I keep it on a charger during the Winter Months or when not driving for extended periods... Had to replace the AUX battery once.
Old 06-30-2023, 04:09 AM
SPONSOR
BenzNinja's Avatar
WWW.BENZNINJA.COM
no issues, keep your battery, you can always do it later. no hurry
Quick Reply: W222 AMG S65 lithium battery change instructions
