July 2023 map download
https://www.me.mercedes-benz.com/pas...ap-update.html
1) MB Connect says mine was synced 4 days ago BUT
2) I checked a few days ago and it said 2019 map? I will check again next time in car.
much easier, no hassle, no mistakes
I'm all Apple/Mac so had to download an app to format a USB drive to ExFat. I've used NTFS for Mac in the past and used it again - I'll probably just buy it. And I had to buy a bigger capacity USB drive. The biggest I had was 8GB and it doesn't go far nowadays.
Did you really say it takes 1 hour to download and 1 hour to install in the car? Do you have to leave the car on for that long? Seems it would really run down the battery.
I checked again and I'm still seeing "The vehicle data was synchronised three days ago" but when I check I still see version 19??? I'm in SE USA.
My guess was about an hour each - it's in my garage/office so I looked at it occasionally. I have it connected to a 4.5 Amp Battery Tender so no issue with the battery. I left the door open so marker lights stayed on. The Command system went dark once and it kept downloading, I woke it up and it was still working.
So maybe it took longer than an hour - it worked as I worked.
