S-Class (W222) 2014-2020
Do i need to change transmission oil or not?
Old 09-29-2023, 11:47 AM
vgahdmi123's Avatar
CLS350D
Some are to go with it, some are against it, i checked car manual and there is nothing about it.
What is general Mercedes reccomendatio, do i need to change transmission oil, and if yes when is the appropriate time to do it?
My W222 is 2018 with 30k miles on it, so far not changed oil in transmission.
Old 09-29-2023, 12:02 PM
chassis's Avatar
Received 3,971 Likes on 3,121 Posts
2017 GLE350 4MATIC
Change it. MB says to do it. Maintenance booklet in my signature link or search this site.
Old 09-29-2023, 09:24 PM
vinflouen's Avatar
2019 W222 S560 4Matic /2019 Chevy Suburban Premier
Change it, and open the torque converter, there is about 4 liters in there as well
chassis (09-29-2023)
Old 09-29-2023, 11:53 PM
SPONSOR
ChrisHimself's Avatar
11 E550, 16 AMG GTS, 13 S550
do it every 30-40k
the later you wait the sooner the next interval will have to be due to trapped old oil contaminating the new supply. the old stuff cooks off, becomes thicker viscosity, and is more or less useless so if it mixes its essentially diluting the hydraulic and lubricative properties it should have
mercedes did not factor for this, so their intervals are often 60k and the cars aren't running as well as they could all the time
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Service Manager/Owner
Amsoil Independent Dealer #7236674
Old 10-01-2023, 02:46 PM
blackbullit's Avatar
2013 ML350, 2019 S560
Would change at 60k. That’s what I’m doing. Would do sooner if car has been driven thru deep water.
Old 10-02-2023, 09:11 PM
mercedesbuff's Avatar
'20 GLS450, '17 S550 Sedan
What is general Mercedes recommendation, do i need to change transmission oil, and if yes when is the appropriate time to do it?
My W222 is 2018 with 30k miles on it.
Here is the recommended interval, per the MY2017 Maintenance Booklet. Your 2018 has the same 9-Speed Transmission as the 2017, so it's reasonably safe to conclude that a 60k-interval would be applicable to yours, too. (Change the transfer case oil as well, if yours is 4-MATIC)
If someone has a MY2018 Maintenance Booklet and can weigh in here, go for it, but I think you're safe with a 60k interval.
Good luck!
The following 2 users liked this post by mercedesbuff:
chassis (10-02-2023), Donnymac (10-03-2023)
Old 10-03-2023, 06:52 AM
Bigg Willi's Avatar
2016 S550, 1997 LS Swap Silverado. 2010 Jag XFR, 2003 G35 Sedan, 1999 LS6 swap Z28.
There is no such thing as "LIFTIME" Transmission fluid, that said just order the whole kit from FCP Euro for your car and watch a couple YouTube vids on changining the fluid on a 722.x trans or W222 chassis Benz, it's pretty straightforward, I change mine every 30kmi. Goodluck!
Old 10-04-2023, 06:51 AM
vgahdmi123's Avatar
CLS350D
since transmission oil reccomended interval is 60k i will wait then and replace on 60k, now i am on 40k
Quick Reply: Do i need to change transmission oil or not?
