S-Class (W222) 2014-2020
Spending the summer in Europe, a little concerned about the battery
Old Feb 10, 2024 | 12:26 PM
kgaddie's Avatar
2016 Mercedes S550, 2015 Lexus GS350, 2005 Lexus LS430, 1998 Cadillac Seville STS
I'm doing a 14 week trek throughout Europe this summer, I'm a little concerned about the battery dying over that time frame. Any tips or charger devices you'd recommend? I don't trust anybody to drive my car while I'm gone (16 S550) so I won't consider that. If I do need to buy another battery when I get back, will it need to be programmed like on the 7 Series?
Old Feb 10, 2024 | 12:48 PM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Get yourself a battery tender.
Old Feb 10, 2024 | 02:13 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
And set it on 'maintain' not 'charge'--ask me how I know.
Old Feb 10, 2024 | 02:29 PM
superswiss's Avatar
2019 C63CS
As suggested above, just hook it up to a tender. CTEK tenders are often recommended by people and it's what the MB OEM tenders are. The one thing to watch out for is I believe the W222 uses a lithium battery, so you need a tender that supports lithium batteries, because they have a very different charging profile and are most happy if kept at a partial charge.
I did a similar trip back in 2019. Spent about 10 weeks in Europe. I put a fuel stabilizer in the tank for extra piece of mind. Inflated the tires to the max load pressure to help avoid flat spots and hooked the AGM battery up to a tender for the entire time. I also changed the oil just before I left. It's something that's often recommended if the car is left for an extended time, but mine happened to be due for regular maintenance anyway.
Old Feb 10, 2024 | 03:22 PM
roviw1's Avatar
2015 S500, 2016 GL63 AMG
My 2015 model S500 has an AGM battery, I think the Lithium batteries were used in the newer models on the W222, my ctek MXS 5.0 has a button to select AGM when used.
I also recommend putting the tyres up to maybe 50psi to save flat spotting the tyres.
Old Feb 10, 2024 | 05:21 PM
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
I've had two W222s.... and same as every year, we also go to Europe and spend about 6-7 weeks in a row, overseas every-year. Never had issues with either of my W222s. They've started immediately like normal, and both were running the factory warranty and were a few years old.
Old Feb 10, 2024 | 07:26 PM
NbyNW's Avatar
Veteran: Navy
Various
I’ve used Deltran Battery Tenders for 20 years or more. I have one hooked up to my 2020 W222 now and two others connected to my other cars - one very nice car and a daily driver. They work.
They were available at Costco but they all show out of stock. Also available at Lowe’s, Amazon, etc.
Edit: As mentioned ^ bump up the tire pressures.
Old Feb 11, 2024 | 01:36 AM
BenzV12's Avatar
W212 FL
CTEK or any battery tender should do the work but I have not come across issues when the car has not been driven 4 weeks .Mercedes-Benz is not a battery killer to me unlike other brands
Old Feb 11, 2024 | 11:36 AM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Did a tour in the mid east for about 4 months, car started up just fine after 4 months.
stop worrying.
Old Oct 16, 2024 | 12:39 AM
MurrayG's Avatar
AMG GTS (2016), GL63 (2016), SL63 (2022) -- Old Cars: E400, CLS 63s, ML 63, CL 600, S550 ...
stop worrying.
Interesting! Which car was that? I have a 2016 GL63 and have to store it for 4 months in a place with no ability to plug in a maintainer.
I assumed 4 months would kill the battery flat. But maybe I am wrong?
Thoughts?
Old Oct 16, 2024 | 04:19 AM
BenzV12's Avatar
W212 FL
Thoughts?
I would unplug the negative battery cable but despite that it would be a vein attempt because 4 months is a bit long time for me as well
Old Oct 16, 2024 | 07:40 AM
W205C43PFL's Avatar
Unplugging the battery might reset certain system functions and needs to be calibrated and/or relearn. For example there might be a chance the windows need to be relearned to close properly (open the windows and hold it for seconds, then close it and hold down for seconds), there might also be an SRS aigbag light. The time needs to be set again, the transmission shifting behaviour might be different for the first few miles, etc.
Old Oct 16, 2024 | 08:20 AM
stever500's Avatar
2025 S63. 2022 911 Turbo S, 23 BMW M5C
I have a 2018 S63, I don't drive it for months at a time, never, ever had an issue. Starts RIGHT UP.
Old Oct 16, 2024 | 08:57 AM
W205C43PFL's Avatar
Starts loud too I bet : ) nice car.
