S-Class (W222) 2014-2020
tire, 2022 S580
Old Apr 15, 2024 | 11:30 AM
Tom1961's Avatar
2022 S580
Smile tire, 2022 S580
I have a 2022 S580. A tire is trash now after hitting a pothole. The place I trust for a tire said that in the manual it will say if I can put a different brand tire on, they said on some model Mercedes you can, and some you can't. Apparently the manual doesn't address the issue. The tire is a Hankook 255 45 19 ventus s1 noble 2. Is it okay to get different brand of the same size (one out of three tires)? Or not? Thanks for your help? Have a great day.
Old Apr 15, 2024 | 06:34 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
This is the W222 S Class, 14-20 forum...but I would not do that personally. For me, I would replace all 4 tires so they match (and did just that, a couple months ago)
Old Apr 15, 2024 | 09:18 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
That tire did not come with a Mercedes.
On the same axle you want to keep same tire and similar wear ~25%. The further you deviate from this the less predictable handling dynamics become.
Old Apr 15, 2024 | 11:10 PM
SW20S's Avatar
2024 S580
Actually yes it did. W223s come with Hankook tires.
Old Apr 15, 2024 | 11:14 PM
VII's Avatar
VII
Well that is certainly unwelcome news, they already used to cheapen out on some models but never to hankook and on the S...
Old Apr 16, 2024 | 12:27 AM
BenzV12's Avatar
W212 FL
Sorry to hear about your tire but honestly, on same axis it's recommended to use same model and brand . Because different tread styling can also affect handling even braking performance . I don't think you're asking it because you can't afford to buy new tires but please don't try different blend .
I know BMW in some newer models too , uses different tires for front and rear but they are same brand on same axis as well
I have seen Hankook as factory equipment even in A Class but if W223s come with that I would like to think :
1- Hankook as tire manufacturers has been making great tires , we can talk about a huge improvement
2- Mercedes-Benz don't want to splurge money on tires and want to cut some corners
I hope it to be about the option #1
Old Apr 16, 2024 | 12:27 PM
SW20S's Avatar
2024 S580
Huge pet peeve of mine. Our new Pacifica came with Nexen tires. I mean, $62,000 vehicle they cant put name brand tires on it? For Mercedes thats even more embarrassing.
Old Apr 17, 2024 | 02:46 PM
Lou B's Avatar
Veteran: Army
Mercedes S560
Your forum choice is oka9y...
The same thing happened on our '18 S560 a couple of years ago. For two reasons, we put four new tires on it: one, the tire dealer, who, of course,was going to have a much larger sale, (I would have done the same thing.0 felt it was better,and two, due the mileage/read on the other three tires, it made sense to me,
You didn't miles or treads - you pays your money and makes your choice!
Old Apr 17, 2024 | 09:24 PM
SW20S's Avatar
2024 S580
The issues at play here are:
1. AWD. The AWD system supposedly needs similar tread depth at all 4 corners otherwise it can cause long term damage to the system. Do we 100% believe this? I dunno..we have staggered wheels and tires and the fronts or rear run out faster than the other axle all the time, nobody worries about that and the AWD system...
2. Traction differentials. Different tread designs shed water differently and have different handling characteristics. Is it a good idea to have different traction characteristics at the front than the rear? I wouldn't think so. Is it good to have different traction characteristics from the right side to the left side on the same axle? I wouldn't think so even more.
3. Jankiness. Having mismatched tires is just...janky. For all the money one spends on a car like this, surely an additional $1,000 for 3 matching tires won't break the bank. Or at least one additional tire that matches the one you're replacing that still matches the remaining two.
We had two flat tires on a brand new Chrysler Pacifica last fall, on a trip.1,200 miles on it.
Had it towed to a local WV WalMart which was the only option, all they had were crappy off brand tires, so I bought two. When I got home, I ordered 4 high quality name brand tires (the OEM tires were also crappy Nexens) and threw away the two offbrand tires I had just bought and the two remaining crappy Nexens. Tires are the only thing that connects the car to the road. Not a place to skimp IMO. To me, this would be a great opportunity to ditch those crappy Hankook tires that MB should be ashamed to have put on the car in the first place and get a great set of high quality Michelins, Pirellis etc.
Old Apr 18, 2024 | 10:16 AM
Lou B's Avatar
Veteran: Army
Mercedes S560
AMEN, BROTHER, AMEN!!
