Lower Control Arm Torque
Did both, all good. Getting the nut off the ball joint was fun. The question now is getting it back on.
Ordered a new nut (book says not to reuse). It has to be torqued to 240Nm
How exactly do I do that?. I have a 24mm wrench and then adapter to put a torque wrench on it.
But the front end moves and I wont be able to get that much torque in there. Also no way to get a impact gun in there (book also says not to use)
Is there a trick to get it to not move? Stick piece of wood in somewhere?
Regarding the torque spec, my assumption is once you have that big monster up close the spec, then you will be able to turn it the last little bit with your 1/2" torque wrench to the final torque. In other words, once the nut is on there tightly enough there's enough friction on the taper that the BJ will no longer turn. The only other solution I can think of would be a 24 mm 12-point crow foot on your torque wrench for final tightening.
I haven't been able to find where you can buy those big nuts by themselves, do they have a Mercedes part number or did you find them elsewhere?
Good luck and post what you work out with these monsters!
- T50 Torx L shape Key to keep the balljoint from spinning
- 21mm deep socket for the outer tie rod
- E Torx 10 for the bolts around the wires
- 24mm 12 point wrench for the balljoint
- 2x 20mm wrenches for the bolts under the car
Used a 24mm short striking wrench to get them loose. Just a lot of hammering. If I had to do it again I would get a magnetic induction heater on the balljoint bolts first. Just to get them a bit bigger. 240Nm in that small a space is no joke.
The other arm might be easier to get to as the balljoint nut is at the bottom, but you have to mess with the struts.
Also, need two 21 mm wrenches for the bottom bolts, not 20mm as in the pic.
Forgot to mention, because I haven't done that. Tighten the balljoints, but don't tighten the bottom bolts until the car is on the ground. I will use ramps.
I will probably take it to alignment in the next few weeks, but I doubt it will change a lot. It does not seem like you can do any alignment adjustments with these control arms.
I had an old truck once where you could make changes to the alignment with the control arms. I might be wrong, but the only adjustment I can see is in the tie rods.
WIS only notes alignment when you do the tie rods, not this control arm.
It took me a while because I have never done it, but if I had to do it again right now it would be a Saturday morning job.
I had the wheels balanced and it all checked out. When I had an alignment done, the technician said the one arm was bad. Replaced both arms and the vibration is 100% gone.
I ordered longer 21mm wrench and I will check it again when I do an oil change, but so far nothing has fallen off, and I really don't think it will come loose. 180 degrees is ridiculous.
Oddly enough at the same time I had ordered 2 packs of $2 GKN axle grease from FCP and they messed up my order twice. First time they sent me a BMW battery cable then second time they only put 1 pack of grease in the box. FCP is in the next state over so i usually get orders in 1 or 2 days, I told them if they sent me a return shipping label I will ship back the battery cable which is listed for over $100 and the woman said there is no need to and keep it.
