S-Class (W222) 2014-2020
Over the air updates
Old Nov 23, 2024 | 07:49 PM
gumshoe100's Avatar
2019 S450 4matic
I have a 2019 S450. My me connect app shows an over the air update available from 2/28/24. It is a map update to a map version older than the one currently installed. I have v27. It’s been trying to upload v22. The dealer had the car for 6 weeks and could not fix it. Is there a contact I can reach out to at Mercedes national level to escalate this repair? This is also preventing me from using the online map update feature. I would be interested in hearing about anyone’s similar experiences and possible remedies.
Old Nov 23, 2024 | 07:59 PM
superswiss's Avatar
2019 C63CS
Can you be more specific with what happens exactly? I have several of those updates that I superseded by doing a manual update for the whole map. The OTA update then just tries to install, but quits with a message saying that it's no longer applicable and that's it. It'll show as uninstalled in the app, but it never tries to install it again. You can manually download the latest map update from the web portal. They just released a new update today. Got the email a couple of hours ago and already downloaded the whole map onto my SD card and it's currently in the car to finish installing next time I drive.
EDIT: Include screenshots of what you are seeing in the app and pictures of what you are seeing on the software update screen in the car.
Old Nov 24, 2024 | 11:40 AM
gumshoe100's Avatar
2019 S450 4matic
You describe exactly what I did. After I manaully updated from the web using a usb stick in June to V25. I got a notice that a new update is available on 11/23 to v22, It just got stuck at that point and I could no longer use the online update.
Old Nov 24, 2024 | 11:42 AM
gumshoe100's Avatar
2019 S450 4matic
After the dealer worked on it in July of 2024 the OTA update available changed to 2/2//24 V22.
Old Nov 24, 2024 | 11:45 AM
gumshoe100's Avatar
2019 S450 4matic
What is the latest version?
Old Nov 24, 2024 | 01:30 PM
trigital's Avatar
W213 All-terrain
Latest version for North America and NTG5.5 is V27.
Maybe your dealer have to make a SCN coding for your Head Unit, as this is the only way for the MB server to get updated with your manually map update. During the SCN online coding, the data from your Head Unit will be redocumented into the MB Server, so maybe you will not receive any notification about updates till a new version will be available.
Now the server is aware only about the legit latest installation.
Old Nov 24, 2024 | 01:44 PM
gumshoe100's Avatar
2019 S450 4matic
Thank you. That is my current version. All the time I had v25 I never received notice of new versions. When did you get notified of v27 being available?
Old Nov 24, 2024 | 01:50 PM
trigital's Avatar
W213 All-terrain
I only use MB Downloader
https://easyupload.io/oofecj
Old Dec 10, 2024 | 10:20 AM
Mr_Sheen's Avatar
2019 S450 4Matic
I also have a 2019 S450. The OTA updated map to V28.0 this month.
Old Dec 10, 2024 | 01:50 PM
gumshoe100's Avatar
2019 S450 4matic
Thank you. I have not received any notices yet. But my app still shows trying to update to V22.
Old Jun 19, 2025 | 12:19 PM
gumshoe100's Avatar
2019 S450 4matic
The dealers have been no help. It seems there is no solution for this issue. I followed Sinotgod and tridigital instructions and was able to get the data file onto a USB for V28. Now I need the activation code:
Tridigital my VIN is WDDUG6EB9KA484621 and I have comand NTG 5.5 Thank you.
Old Jun 19, 2025 | 01:22 PM
Mr_Sheen's Avatar
2019 S450 4Matic
V29.0 map update
Just got V29.0 map update over the air. Do you have access to live traffic? Perhaps it's somehow connected?
Old Jun 19, 2025 | 01:33 PM
gumshoe100's Avatar
2019 S450 4matic
Yes I have live traffic seems to work. Good to know v29 is out. I don’t know what to do to get this fixed. I may give Benz ninja a crack at it. The car is still under CPO warranty.
Old Jun 19, 2025 | 02:37 PM
gumshoe100's Avatar
2019 S450 4matic
I am going to update to V29 using MB tools.
Old Jun 19, 2025 | 03:34 PM
trigital's Avatar
W213 All-terrain
If you ask me, may receive a free Activation code for V29 North America maps for NTG5.5
Old Jun 19, 2025 | 03:51 PM
gumshoe100's Avatar
2019 S450 4matic
Trigital can you supply activation code for V29, NTG5.5 region North America vin;WDDUG6EB9KA484621. Thank you
Old Jun 19, 2025 | 04:51 PM
trigital's Avatar
W213 All-terrain
Try this:
SKXOZF
NTG5.5 V29 NA
Old Jun 19, 2025 | 05:44 PM
gumshoe100's Avatar
2019 S450 4matic
Try this:
SKXOZF
NTG5.5 V29 NA
Thank you
Old Jun 20, 2025 | 09:26 AM
gumshoe100's Avatar
2019 S450 4matic
It worked. Thanks trigital for the heads up on the erase option. That option got me thinking. If I erase the data would the outdated map update then be aloud to complete? I am still stuck on map v22 sitting in queue.
This would then free up my OTA update options or do I have bigger problems.
Old Jun 20, 2025 | 09:34 AM
trigital's Avatar
W213 All-terrain
If V29 was successfully installed, no need to do anything more. The OTA maybe will forget about you at some point. Anyway the OTA for 5.5 almost never worked.
Old Jun 20, 2025 | 12:50 PM
gumshoe100's Avatar
2019 S450 4matic
That’s good know.
