S-Class (W222) 2014-2020
Rear Axels Rubbers Greasy
Old Jul 20, 2025 | 11:29 AM
ageeltm0's Avatar
Maybach S560 2019
Is this serious?
see attached pics.
Old Jul 20, 2025 | 01:36 PM
Kent agent's Avatar
S600 w222
change the oil and put in 3% omega 917 after 20 miles closely
Old Jul 20, 2025 | 10:27 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
It's not good, check differential level.
If leak is slow you could get by with annual differential top off.
If your differential runs low you'll end up needing to replace it.
Old Jul 21, 2025 | 08:51 AM
Digital Oxygen's Avatar
One of them there S cars
What are you talking about? He probably didn't use Genuine Mercedes Magical Differential Fluid that meets Mercedes spec UN1C0RN UR1N3 333.261, and it's obvious the magic built into the original fluid is wearing off!!!
But seriously, OP. VII is correct. Check differential fluid level and address it as necessary. On the bright side, those leaks are going to eventually stop when most of the oil runs out of the pumpkin. At that time, expect serious damage to start occurring. The trick is to repair or stay on top of the oil level. Keep in mind, the leaks can (and probably) will get larger.
Old Jul 21, 2025 | 05:25 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Diff fluid or grease seeping from the CV joints? I've had cars with bad CV boots that look like that ...
Old Jul 21, 2025 | 06:45 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Looks like he CV joint boots are leaking to me too. Should replace them, unfortunately replacing the boots can cost almost as much as boot replacement.
Old Jul 22, 2025 | 04:05 AM
ageeltm0's Avatar
Maybach S560 2019
I believe it CV boots, not differential!
Old Jul 22, 2025 | 11:02 AM
VII's Avatar
VII
Ahh in that case I would say you'll need to replace when it starts making noise.
You could regrease from time to time but that is an annoying job.
Old Jul 22, 2025 | 11:58 AM
chassis's Avatar
2017 GLE350 4MATIC
Torn boot. Needs replaced. The joint will fail if left long enough.
Old Jul 22, 2025 | 12:36 PM
Best to put in a new axle when the time comes. Wear on the CVs on both ends and possible infilration of dirt and water where the grease has started to leak out.
Labor to do the whole axle is no more, possibly less, than replacing a boot and repacking an old CV joint
Old Jul 22, 2025 | 05:06 PM
Alexie's Avatar
Yep, just swap the whole axle cheaper in the long run and saves the hassle of rebuilding a worn CV.
Old Jul 23, 2025 | 09:58 AM
JohnLane's Avatar
222 S-65
OP keep an eye on it with every oil change. When it gets to where the C/V boot is ‘throwing grease’ it is time to replace. It can look like your photos for months to years.
Old Jul 23, 2025 | 03:06 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Quite obviously bad CV joints throwing grease, needs new axles
Old Jul 24, 2025 | 03:35 AM
ageeltm0's Avatar
Maybach S560 2019
Actually few months
Old Jul 24, 2025 | 03:39 AM
ageeltm0's Avatar
Maybach S560 2019
But spare parts for one axle is around $2500/excel!
