How long should MBC struts last on a 2018 S560 roughly?
Its very very pressurized, a leak would cause a fairly rapid loss in fluid for the 10+ years I have with hydraulic MB suspensions going back to the 90's and the silly hydraulic convertible tops from the R129's.
I recall the struts for these being like $1700 a corner? I'm probably wrong and it might be for the airmatic though. Labor + a couple hundred in fluid is $185 at any decent shop. But no, no strut lasts 200k, they are wear items and the harder you use them the sooner they go. The S Class burns through parts much faster than the E and C models. MBC is Rolls Royce level technology its GOING to be expensive
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Mercedes-Benz Magic Body Control (MBC) struts typically last between 50,000 and 100,000 miles. However, their actual lifespan is highly dependent on driving conditions and vehicle maintenance.
Factors Affecting Lifespan
- Driving Conditions: Frequent driving on rough, uneven roads with potholes and speed bumps accelerates wear and tear.
- Vehicle Load: Consistently carrying heavy loads or towing puts extra stress on the suspension system, which can shorten the lifespan of the struts.
- Maintenance Habits: Regular inspections can help identify issues early. A qualified technician should inspect the suspension system every 12,000 miles or once a year.
MBC struts should be replaced immediately if they are damaged or leaking fluid. Other common indicators that the struts need replacement include:
- A noticeably bumpy or uncomfortable ride.
- Poor handling and instability, such as excessive body roll during turns or a feeling of looseness.
- The vehicle's nose dipping excessively during hard braking ("nose-dive").
- Uneven or "cupped" tire wear, caused by inconsistent contact with the road.
- Unusual clunking or squeaking noises from the suspension.
My 222 S-65 also has a front strut that is wet. 150,000 miles.
Replace all four? Nope! Wipe the oil off every time it is on a hoist.
Change the MBC oil and fluid filter. Easy to do.
My understanding is an MBC strut contains a steel spring with a hydraulically-operated movable top spring perch. You can feel the spring under there by pressing on the plastic cover. I am not sure how damping occurs exactly, one would think the same mechanism that allows the spring perch to move dynamically could also provide damping, but there might be separate dampener in there too. In which case, the separate dampener could wear just like a conventional shock absorber and then require the whole strut to be changed.
Has anyone changed an MBC strut and felt an improvement in ride and control afterwards?
Much less money than oem and says two year warranty. Could have an independent shop replace the fronts for now if necessary. I guess though probably a little seepage is fairly normal as these get older especially after the cars been sitting around for the past 6 months and then up and down on the lift a few times. Strange that the dealer who recommended changing out all 4 struts didn’t even think of checking the hydraulic fluid level in the reservoir at least until I mentioned it. That’s kinda a red flag right there.
I then removed most of the fluid from the reservoir tank using the electric pump. Then I filled with the same amount (1 liter) with the funnel then put back in the filter assembly and checked the level and took the car out for a work in drive turning up and down the suspension level control and put in curve mode and drove some winding roads. All is good I swear the suspension seems smoother now. In about a month at I’ll pump out the fluid in the reservoir again through the dipstick tube without removing the new filter and refill with another fresh liter.
Not ideal but chances are at over 81k miles an accumulator is gonna go anyhow and gonna get another fluid refill when the fluid leaks out from that. I’d still like to know how to replace the accumulators. I think there is one at each Strut?
If nothing else I could advise the shop wherever I get stranded how to do it and the part number. If they are all the same it might make sense to carry a spare accumulator in the trunk? Trying to stay ahead of things with this higher mileage 2018 S560 Benz.
Oh, and Happy Turkey Day!
Happy Thanksgiving to all!
Where is the 'low pressure accumulator' hidden for the 222? Poking around I find the Accumulator on the front valve body, another that pokes into the trunk and the little one on the ABC pump.
I have the pair of them for front and rear (same as 221 S-65) on the shelf and intend to replace when time and interest come together. They look like a treat to do. Didn't think I would need to purchase another wrench in my lifetime but I don't have the one for that front accumulator that looks to be about 27 or 28mm.
For the front accumulator, I just needed to remove the underbody panel and the lower horn. Then I used a big rubber strap wrench around the whole accumulator to unthread it from the valve block. I also don't have a 27 mm wrench, but there is basically no access to the hex unless you remove a bunch of hoses.
For the rear accumulator, it's a real treat. First, remove all the trunk paneling to gain access. Then from below, remove a diagonal cross brace, left side exhaust/muffler, and muffler heat shield. Then you'll have access to the 3 bolts and hydraulic connection for the rear accumulator from the underside of the car. I don't believe this really improves access to the low side accumulator, so I don't think there's a big advantage there. The return accumulator is also the most expensive ($366)
On my old 2003 W220, both the front and rear accumulators had failed between 95K and 120K miles, and the return side regulator failed by 150K miles. After those replacements, the ride height sensors, 2 lines up front, 2 struts (failed travel sensor and external fluid leak), and a vertical accelerometer, the system was still working at 197k when I sold it. Be proactive, look at the struts for leaks when you change tires, and have Xentry or a similar diag unit to troubleshoot sensor issues. It's really not too bad if you are prepared. I survived the first gen system, so I figure the newer systems should also go the distance.
For reference, I had used Corteco accumulators front and rear, Amazon generic ride height sensors, ebay used OEM accelerometer and struts. The total cost of all of the ABC parts was under $1,000 in 100K miles of ownership.
