Guys... My 2015 S-65 is dripping blue coolant from the driver’s side frame rail while running.
No coolant leaks under hood.
No coolant hoses I can see on driver’s side.
Charge coolant is pink so not that.
Thoughts?
Thoughts?
OldManAndHisCar
close
- Join DateJun 2021
- LocationFleriduh
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveW212 E63S Wagon - GSL580 - E63 - E350 - C300
Liked:1,354 Times in 993 Posts
Engine rear to firewall - there are hoses....they break (mine did). Not sure about your engine specifically but my coolant temp sensor was back there as well...and leaking.
Might be a stupid question but are you sure it is coolant and not washer fluid?
Quote:
I'm with ya on washer fluid. The color suggests wiper fluid. Originally Posted by superpop
Quote:
Coolant is a darker color than washer fluid and it tastes sweet. I compared on paper towels. Originally Posted by James S
Trans oil is blue but doesn’t feel like this on fingers.
Also.... drips when running.
No coolant lines on driver’s side. Zero signs of a leak at the engine. No scent of coolant under the hood. I can smell hot coolant every time under the hood.
Quote:
Went to some effort at exposing things. All plastic off top and bottom. See nothing at base of windshield or moving down driver’s side. Originally Posted by OldManAndHisCar
I have it on the hoist and am clearly missing something.
Kent agent
close
- Join DateDec 2024
- LocationUppsala
- Vehicle(s) I driveS600 w222
Liked:13 Times in 13 Posts
Looks like the shock absorber is damp so maybe oil from ABC suspension?
vinflouen
close
- Join DateJan 2009
- LocationIn The Woods
- Vehicle(s) I drive2019 W222 S560 4Matic/2025 Yukon Denali
Liked:261 Times in 148 Posts
motor mounts?they drip blue when they go...
ExploreQuote:
ABC/MBC oil is amber in color. Yes; I get to wipe the left front strut with a paper towel when I have it on the hoist. Originally Posted by Kent agent
It is leaking from the chassis right next to the strut.
Quote:
Zero leaks on engine. The Goo that comes out of engine mounts is a very different color and not coming from mounts that I could clearly see with the car on the hoist and all plastic removed. Originally Posted by vinflouen
motor mounts? they drip blue when they go...
This one is quite the head scratcher.
carlosinseattle
close
- Join DateAug 2007
- LocationPacific Northwest
- Vehicle(s) I drive2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Liked:793 Times in 567 Posts
If it were me I would clean the area as well as poccible, even if only from the top. Then drive for a short time, slowly so that things don't spread out as far, then come back and get it back up on the lift to see how things look.
Quote:
Did that last night Carlos. Fresh drop hanging from same spot tonight after commuting to and fro.Originally Posted by carlosinseattle
Kent agent
close
- Join DateDec 2024
- LocationUppsala
Fuchs Titan 11s strongly resemble the color you have especially when lightly used
Are you positive there is no coolant dripping down the side of your oil pan toward the front of thew engine? I have a leak/drip, my water pump and all the usual places are dry but still a steady drip off the passenger side of my oil pan once I pressurize the system above 12 pounds. I finally figured out it's a failed seal on the main front timing cover. Since it's failed up high there is no coolant anywhere on the front of the engine, just a drip along the seam where the cover meets the block. Needless to say, I wasn't very happy when I figured out the source.
Quote:
Zero leaks under-hood. No leaks inside the engine compartment. Zero leaks at the stack of heat exchangers. This leak is on the outside of the chassis in the wheel well. I went to considerable effort at looking for a path for coolant to get in there. Not seeing it.Originally Posted by MrLan1
dmatre
close
- Join DateFeb 2003
- LocationCharlotte, NC
- Vehicle(s) I driveHad: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Liked:340 Times in 191 Posts
Did you run over Spock?
Mystery solved. Pull all plastic at cowl. Crane neck whilst shining flashlight and hold mirror..... The plastic guy that goes through the firewall and feeds heater has a hose on it that is leaking. It runs down to the driver's side and ends up pooling in side the chassis at L/F next to the strut. Not an expensive thing but sure looks like a treat to replace. I have a Saturday project. Woo-Hoo!
OldManAndHisCar
close
- Join DateJun 2021
- LocationFleriduh
Quote:
I have felt your pain - LOL - Originally Posted by JohnLane
Keep your soldering iron handy to melt out the broken bits of coolant pipe in the engine...in the tightest, hardest to get to place ;-)
So your charge coolant is pink and your main coolant is blue?That car did not leave the factory with two different coolants.
Quote:
Indeed it did. Is handy being able to know which system is making the mess. Originally Posted by VII
The blue and red flavors are interchangeable; but only with a thorough flush. They are not to be mixed.
Up until now the worst leak has been the charge cooling reservoir and engine coolant reservoir caps. 11+ year old plastic.
Replaced hoses and plastic bits. The guy that snaps into the firewall had developed a hairline crack on the cowl side of it. That assembly arrives with two hoses. Also replaced hose that clips into the plastic guy and goes to the pax side head. Pretty tight on the back of the engine and in the cowl. Cut my big meat hooks up pretty good. Three hours of effort start to finish. Zero drama. Nothing broke. Things are tight in there so getting to clamps was a treat. Worst was the hose on the head. I’d have the guys at the dealership do it, but not for the nine hours of labor they quoted.
Kent agent
close
- Join DateDec 2024
- LocationUppsala
I have the pink coolant in both systems
Is it standard with blue for the intercooler?
OldManAndHisCar
close
- Join DateJun 2021
- LocationFleriduh
Quote:
Exactly! The older I get the more I think that of some fool working at the dealership can do it so can i. Every single time I try one of these harder tasks somehow I'm always able to accomplish it in far less hours than what the dealership quotes.Originally Posted by JohnLane
I have heard stories that in early V-12 cars (produced 2014 and 2015) engine coolant blue; charge coolant pink (as in my car). I did not buy my car new and thus am unable to confirm and am unaware of when MB changed to pink. Originally Posted by Kent agent
I have the pink coolant in both systemsIs it standard with blue for the intercooler?
Mercedes offers pink as OE today. They stock blue in an aftermarket brand. Zerex if failing memory serves.
I like having different colors for the two cooling systems as I can see at a glance if a leak is charge or engine coolant.
If changing from one color to another; flush thoroughly with water to get all color out.
Quote:
Exactly. I’ve been a tech all my life. MB quotes astronomical labor figures to do things like engine mounts. “They have to pull the engine to replace them!” Um... BS! I was quoted something like 6.5 hours to replace engine mounts in my 211 E-55. First time I replaced them I had three hours in it. Subsequent replacements of mounts (they failed annually) got to under two hours. My 221 S-65 I was quoted over 20 hours “Have to pull the engine.” My first time doing them 3.5 hours. Subsequent replacements (again... failed annually) in under three hours. Seems they don’t need or want the work.Originally Posted by OldManAndHisCar
