heating blows hot when starting
Old Jan 9, 2022 | 03:54 PM
grosdudu's Avatar
W223
Hello everyone
When I start my car in the morning, the heating is very strong at the start, for about ten minutes, forcing me to lower everything to put it back later to the desired temperature.
I guess it is a function "902 Heating and seats more in the front "
It is very unpleasant for me.
Do you have an idea to deactivate this and keep the heating pleasant?
Thanks everyone.
Cordially.
Big Dudu
Old Jan 10, 2022 | 12:31 AM
ColeBlooded's Avatar
Panamera, '63 Impala
What settings are you using?
Old Jan 10, 2022 | 02:37 AM
Diesel Benz's Avatar
Specifically the outside temperature settings.
Originally Posted by grosdudu
Hello everyone
Thanks everyone.
Cordially.
Big Dudu
902 seat heating plus for the front seats is "only" adds heated panels, door and centre console. Does not increase interior temperature in any way. If the ambient temperature is significantly lower than the set interior temperature, the car tries to get everything quickly to the set temperature. A compromise between annoying blower speed and time to reach the set temperature. I'm one who favours smooth blower operation. Not sure if the W223 has any settings to control this. It has been a bit different on different MB models, some more aggressive than others.
Old Jan 10, 2022 | 03:56 AM
bishop64's Avatar
2021 S450 4Matic
Good point!
If outside temp is, say, 5C and the car has sit outside overnight, the interior temp can be, say, 10C. If the desired temp is set to 22C, the fans could then spin in full speed, blasting full amount of hot air.
One remedy is probably not to use 'Auto' and to use manual fan speed control.
Old Jan 10, 2022 | 10:20 AM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
You can ask Hey Mercedes to "turn the fan speed to" (specific number) "1" 2 or 3 and so on and it still stays in the AUTO mode if enabled. I noticed sometimes if you try to slow the fan speed down manually it knocks the system out of AUTO mode.
Old Jan 10, 2022 | 10:50 AM
js_cls's Avatar
I am confused on what the issue is here. If it is too hot simply turn down the temperature and/or fan speed, the HVAC system in the S-Class works like any other car.
Old Jan 10, 2022 | 01:44 PM
True, I've had mine set to 73 auto since the summer I bought and never had to adjust it
Old Jan 11, 2022 | 12:41 PM
grosdudu's Avatar
W223
Hello.
Yes it works like that in all cars and I can lower the temperature and / or the blower then turn it back on or change the temperature later.
But it's much louder ( violent) than other cars and the feeling becomes unpleasant.
And since I do a lot of short trips,
I often regulate the temperature whereas in my other cars I never did. 20 degrees, auto mode and I didn't touch it anymore.
Well, it's not very serious, just annoying.
Have a good day
gros Dudu
Old Jan 13, 2022 | 04:05 PM
Benz580's Avatar
W223
Make sure the AC button is on. I believe even in auto mode the AC button can be switched off. I leave AC on all the time. Even when heating! Keeps humidity down. Less chance of fogging etc.
Old Jan 16, 2022 | 08:15 AM
Sonic Boom's Avatar
2021 S500 (Mojave Silver), MB S400 (wife), BMW 750Li (passed on to kids)
Is that with the “AC” button switched on or off?
Old Jan 16, 2022 | 12:49 PM
The AC button is always on. I find that the cabin gets stuffy with it off.
