Not disappointed with the S580, with Mercedes Benz USA and with my dealership
After a few months of back and forth between the service departments - complaining about serious ride quality issues - My MB dealership and I finally worked a deal on a brand new S580 - and it does not disappoint.
Last edited by zukiper; Apr 3, 2023 at 11:39 PM. Reason: The dealership resolved the situation amicably - and the new S580 DOES NOT DISSAPPOINT - So the title needs to reflect that ;)
Recently purchased a CPO S580 2022 with less than 1500 Miles, that drives awful. While driving on "not 100% perfect smooth roads" your body sways left to right to left to right....like the left and right suspension actuators are out of sync.
In my previous 2019 S222, the airmatic ensured the cabin occupants a very smooth ride. Was like driving on a cloud.
When complained to the dealership, their initial response to me on the phone was "Car drives as designed - there are no issues"
After I persisted that there is an issue - Suddenly they found out that the airmatic AND rear axle steering required software updates. Which they did.
They said that after the software updates the car drives like an S-Class should drive.
IT DID NOT. It drove exactly the same as before.
Then I took it to a closer branch of the same dealership. A different service center.
When complained to this location of the dealership, their initial response to me on the phone was same "Car drives as designed - there are no issues" or "just drive in S+ mode only"
After I persisted very vocally that there is an issue - Suddenly....behold... they found out that the airmatic system has multiple electrical fault codes, as they also had to replace the entire Airmatic Control Unit.
They said that after fixing the valves and airmatic unit - NOW the car drives like an S-Class should drive.
Sadly IT DID NOT. The same body sway exists. It drove a little smoother, as they also reduced my tires PSI from 42 to 30
Third time vehicle went in for service, they agreed to make sure the loaner will be an S580, so I can compare the ride with exactly same type of vehicle on all my regular roads and routes.
The moment I drove their S580 loaner off the dealership lot, I felt the Night and Day difference between the vehicles. The loaner S580 drove like my older W222, no body roll or sway in side the cabin was felt.
It drove like you were riding on a cloud.
The final outcome is that the "numbers" on the computer show that my S580 is normal, so they exhausted all their repair ideas, and the fact that their loaner DID DRIVE 10 times better - is of no interest to anyone.
Which I cannot understand?? Why then offer your client to test drive their S580 loaner, in my main area of driving, allowing me to compare the 2 cars - IF THEY TOTALLY IGNORE the findings.
MBUSA - also do not care. They said it is Not their issue - they said to speak with dealership. (which
Dealership also don't care - since the computer says the car is per specifications. They do not care about the actual symptoms as described by the owner/driver - only care about Fault codes.
Does anyone with an S580, feel they have excessive body roll / sway inside the cabin while driving?? Do let me know !
When driving - do you feel your body rocking from left to right??.
Let me know how many of you have a "superb" & "cloud like" ride quality on your new W223 and how many of you are feeling this annoying body sway inside the cabin while driving.
30psi tire pressure, that’s a hilarious failed attempt by the manufacturer’s stooge agent to cover up a product defect.
In addition to relying on the car's fault codes (objective aspect), the dealership's technician must also give the car some test drives to feel the actual road feel (subjective aspect).
If they have not done a test drive (hard to imagine this omission), maybe you can take their technician a test drive and see what they have to say then?
Also, did you test drive the car before buying? I wonder, this behaviour must be so obvious that it cannot be missed on the first drive.
Maybe you can keep the loaner until the issue is fixed?
A subjective feel of the car having excessive roll is gonna be hard to get a warranty case approved if there are no longer any fault codes. Especially, since the S Class is fundamentally floaty, aloof and soft. I had an S500 loaner while my C63 was in for service and an S Class drives like the boat it fundamentally is. Hard to tell from your description whether there's an actual problem. I mean in Comfort mode this thing floats, dives under braking and rolls around, because the suspension is so soft and the car is heavy. Can't have body control and at the same time be soft like that. Do you have the standard AIRMATIC or the optional E-ACTIVE BODY CONTROL suspension? I had to drive the standard AIRMATIC in S+, because otherwise I was about to get sea sick. The E-ABC suspension uses actuators for better body control while still allowing for a soft suspension and reads the road ahead, so it's a rather complicated suspension and who knows if there are software bugs, which the dealership can't do anything about.
Not sure why the S580 loaner drove differently, but AIRMATIC vs E-ABC could be one reason. Did you check how the loaner was optioned compared to yours?
My sample size of time behind the wheel with my 23 580 is only a few days (21" wheels and E-ABC). I did drive 6 hours in it today mostly on the freeway. Prior to this I had a 580 loner for 3 weeks on 20's last year. I have only driven a Mercedes as daily for 19 years (multiple S classes S63, S65, CL65, etc.) I'm saying that just for reference if that helps. I have never experienced the rocking/swaying you are describing.) I don't want to jinx myself by car drives like a dream. The E-ABC eats up speed bumps like Pac-Man and overall experience is smooth and comfortable. I may be a bit biased because I'm coming from a GT63 which is a different animal.
I sincerely hope you get to the answer of this. It is a frustrating feeling to spend this much on something that you likely spend a decent amount of time in, not to be happy.
I can at least confirm that my car doesn't wallow, sway, etc. It's quite composed and doesn't have as much body roll as I'd expect, given the soft ride. There should be a win for you if it gets sorted out.
I have someone who works for me that has a 911 and she has had a hellish time getting a misaligned window replaced. Finally after 5 attempts to fix it a factory rep is coming into town Feb 2nd to look at it.
My history: I’ve bought or leased 60, brand new cars, of which the majority were higher end luxury cars. I’ve had 17 new MB’s and my last 8 new cars have been MB. My 4, previous daily drivers have been 2013 S550 w/ABC, 2015 S550 w/MBC, 2018 S560 wMBC, 2020 S560 w/MBC, all with 18” wheels and non-run flat tires.
My 2022 S580 is an Executive Line, with 10 degree, Rear Axle Steering, 19” wheels and EABC. I leased it new from a dealer that was about a two hour drive from my home, so I never drove it before it was delivered to me on a flatbed. “THE” biggest mistake of my automotive buying/leasing history and I’ll never do that again.
My car in “Comfort” or “Curve” mode, at speeds under 60mph, picks up most EVERY road imperfection and transmits it to the cabin. Took it to my local dealer, Fletcher Jones in Newport Beach—largest in the USA—and the shop foreman drove with me and he exclaimed how bad the ride was. They kept the car for ten days, returning it to me, saying there were “no codes,” they reduced the tire pressure from the recommended 42# to 35# and pronounced it “fixed.” It still rode horribly, in my opinion.
I replaced the original Hankook run flats with Continental non-RFT. Big improvement, but still NOT NEARLY the ride of my previous four, new S Class sedans. Took it back to Fletcher Jones and THEY reduced the tire pressure to 24# cold, said “No Codes,” and said the car is “functioning as designed.” The car now may have rode a bit better over road imperfections, but the feeling when cornering was mushy, so I inflated to 33# cold.
I complained to MBUSA and “opened a case,” which they have now closed, saying that “the car is operating as designed.” Fletcher Jones has done everything, WITHOUT actually saying it, that they want me to GO AWAY. They no longer return my calls or emails. I tried to make an appointment with another local dealer, but they don’t seem to want my business either. I have this sick feeling that when they put the VIN into their system that lights flash saying something like “PAIN IN THE *** CUSTOMER, SHINE HIM ON!”
Bottom line: On non-AMG cars, all of the optional suspensions, such as ABC & MBC provided a much smoother, very comfortable ride. EABC, at least in my car, does not. Mind you, the handling is great, but the ride quality, is not in the same league as ABC or MBC equipped cars. If you don’t want body lean and handling is your big deal, get EABC. If supreme comfort & ride quality are really important to you, stay with the standard AirMatic. For me, I’m probably done with MB.
To be continued.
Mercedes-Benz: The Best or Nothing. Yeah, right.
One exception are suspensions with adaptive sway bars. They can almost decouple the sway bars in a straight line so the wheels can move completely independent over bumps for better comfort and then when cornering they tighten up to reduce roll etc. I don't believe the S Class has adaptive sway bars. It's something that has found its way primarily to SUVs.
You saying the S Class handles poorly is like me saying the C63S rides poorly. It does, to me but that's not what the car is about or for.
It would be easy to get that wrong but they handle it masterfully and it's all completely seamless. I still think if Porsche decided to make an actual luxury sedan; that car would kick sand in this car's face and walk away with the girl. Kinda makes me wonder what sort of ride the Bentley has in the Flying Spur?
I drove a New Flying Spur when they first came out. Compared to the 2020 S560 I was driving at the time, the Bentley seemed ponderous, bloated and not nearly as buttoned down as my MBC equipped MB. I have not driven a Bentley with their Bentley Dynamic Ride optional suspension, but I’d like to try it.
Audi has the best tech videos:https://www.audi-technology-portal.d...ort-suspension
