ILS+ INTELLIGENT LIGHT & other codes done, FULLY REMOTE! NO RENTAL hardware, low cost
with ILS+ function, if i have the hi beams on manually (ie, not on auto mode), will it still block out cars in front and oncoming so they don't get blinded?
or is that only in auto mode?
i'd like to be able to keep hi beams on permanently (regardless of speed) and have the blocking function activated throughout its entirety.
is that scenario available with ILS+?
I would say usually there is a speed limit before the automatic high-beam turns off (which I think 35 MPH on the benz). I don't see why this can't be coded, but now you gave me a few things to poke my coder with. But I know as of right now it does not work by default the way you want it to be. I'll report back if I learn that this can be done. My rule of thump, usually is, if it can be done on a stupid BMW, the Benz must be at least capable of doing the same lol !
Another feature I really want is: since the cornering lights use a separate light bump inside the headlamp, I'd like them to be always on too. They help a lot in illuminating the sides of the vehicle like a 360 fog light which we don't have
If you use the auto on/off setting for the headlights then you can leave the high beams on all the time and it will always work.
my understanding here is that when ILS is coded in, it's still the same algorithm determining when to turn on/off the hi in auto mode. but with added benefit of blocking out oncoming+front traffic (in addition to the various other lighting enhancements described in the manual for Canada models).
do i have this correct??
Regardless, but to answer your question more specifically about Zenzefi, it is basically US based certificate that ALL (OR MOST) CODERS really use (there is no other way that am aware of) for all vehicles that are using the STAR Architecture. ZenZefi is basically a supplier for (and on behalf) MB-USA, to supply certificates. So ZenZefi basically does the handling and distribution of DCS Certificates for US folks including third part shops. Anyone can get it for 60 bucks and with VPN network connection you cab do coding as if any other US dealers or 3rd party shop would do when using Zenzefi. Both coders in reference of this thread seem to be using a valid Zenzefi as they claim, though Ninja still does not do or offer W223 coding, while Max had already coded a few vehicles here for ILS using Zenzefi certificate. Regardless, the claim against Asian countries originated certificate or source is not even valid (but in all cases and regardless who works/code your car dealer can see it is not his certificate, but do they really care? that I don't know). But US vs non-US based stuff is all BS; it is still appear as US based valid certificate. This is why things will be done using your laptop from your own home, all via VPN secured connection on the coders end. Your laptop USB and it's IP and your network then serves as the direct and only physical direct contact with the vehicle. That's all based on my understanding, I welcome any corrections or comments; simply trying to avoid scaring off people with any bold claims. For W222, it a different story but easier.
If so, does this further imply that if a person's car is modified under the umbrella of an US based valid certificate, that car is still under MBUSA warranty?
What is the relationship between MB factory warranty and having (or not having) coding modifications with a valid certificate?
And as such, no MB dealer in the US can deny warranty work to a car which is modified under a valid US certificate? The answer, AFAIK, is negative.
So, does this mean MBUSA, selling these certificates through Zenzefi, is basically giving their consent to the buyers to do coding modifications?
no, it gives access to recode, modify View/Wtite or just VIEW the ecu's and they are not selling certificates.
D Certificates auto-download and by access with a MB D account and they are locally stored and valid only two weeks only
They are normally not removable nor transferable or can be sold
ZenZefy will write it's access in the car forever in this case a license from Singapore Asia.
Mister "I have a mission" in need of celebrity You have no idea of what you are talking about
nothing to to with bought or online, the original certificate's dealer data will be recorded in the car
This is the reason why I am not providing this service yet. We will be doing this only after we got a Legit US Dealer or Licensed partner's access
BenzNinja works for dealerships and MB licensed work shops since last year
Just ask yourself nobody is providing this service here yet
coding the W223 is the same as any other car. This is not the problem
nobody is buying non-Euro or non North American coding certificates and those licensed with these are not very motivated to lend them
for those who don't know what ILS+ is here is the video
for those who want to know the history:
"Ask a Pro if you don't Know"
The best way to get accurate answers
If BenzNinja's coding work does not affect MB warranty, what is the reason?
Is it because your work is, in some ways, accepted by MBUSA?
Is it because your work supposedly leaves no trace for a MB dealer to discover?
From what I read about, when a MB dealer finds out the recoding, there is warranty problem.
You seem to say ''A MB dealer will find out a Singapore recoding easily. But a MB dealer cannot find out my work as I use a valid US certificate.''
This implies, if whatever recoding is found out, there will be warranty issue.
Frankly, soley relying on ''not-finding-out'' is not up to my standard. I do not entertain this crossing-finger approach at all.
i'll ask a different way...in OEM format coding, can it be run continuously with anti-glare?
Even when it is off though, the low beam pattern is improved.
also, in manual mode (ie, not Auto), you can have the hi-beam on continuously...but it won't do the anti-glare blocking...that only works via Auto mode.
i have this right?
(ok...back to the originally scheduled program of non-sensical bickering)
I have been telling everyone long time ago about the dangers getting your W223 coded with non US licences, the traces it leaves and problems you will get.
It is totally irresponsible to do this
There is nothing to discuss. It's a fact
The prices of a US licences are to high right now, and security not met.
you will have to explain to your dealer how your car went to asia
It seems you are ignoring what the moderator replied you:
"Endorsing a vendor and their coding results for a platform which you don't own or have any experience with is not ok. Nor do you have relevant experience what impact this has on owners. "
Now you won't see a coder in Singapore admitting that his Asian license writes it's access in the W223
you seem very exited writing in red
no need to respond, all I had to say has been said. audience will judge by themselves who they believe
discussion is closed for me. Argue with yourself
ps: If his real name is Max, I am James, James Bond
BE AWARE !
i have this right?
the issue is the width of the rear wheels not the diameter. 255 millimeter rear tires work for full 10 degree, while 285 millimeter limit you to 4.5. I do not know how much extra/room for error is in any of those.
In the US, there are three AMG like 20 inch wheels that have been offered, RVR, RVP, and RVQ. All of those, like the 21 inch wheels, have the wider 10 J x 20 rear wheels on 285 width rear tires. In other markets, though I don’t know the codes, there are similar wheels offered with the thinner 9 J x 20 wheels on 255 tires, and those work on 10 degree rear steering. That’s the real thing to worry about, though, wheel and tire width.
In the US and other markets, all 19 inch wheel options I clouding the AMG wheel, as well as most of not all 20 inch non AMG line wheels should have the thin rear tire and allow 10 degree rear steering.
@Sonic Boom can u please verify, given u actually have the 10deg with the 20" amg wheels...
-for 10⁰ RWS you can go up to and including 20” wheels.
-if you go with the 21” (AMG?) wheels then you’re restricted to 4.5⁰
Personally I prefer to have 10⁰ much more than to have 21” wheels. So it’s a matter of preference: more RWS or larger wheels.
For me it was a no brainer. I’ve posted endlessly on the merits/benefits of 10⁰ as opposed to just 4.5⁰. The difference is amazing!
PS
My 20” wheels are AMG: code RVU AMG multi-spoke alloy wheels with 10⁰ steering code 216.
per @BenjaminKohl looks like ur rear is amg 20x9.
my rear tire here in the US is a 285... which probably means the amg wheel is 20x10.
damn
