Battery malfunction
The dealer could check this up at least in 3 weeks. Meanwhile hooked launch and checked the errors. Starter battery is malfunction (please advice where to find it exactly).
I tested the 2 batteries in the trunk - they're in good shape, also checked the other battery through the charging terminals in the bonnet - its good too.
Any advices to fix prior to the MB Dealer inspection? Where is the starter battery located? Could the problems be connected as in the older MB Cars - SRS was shown when the voltage drops.
Thank you in advance.
Regards!
-lane keeping assist inoperable
-check engine light on
-Distronic plus inoperable
-traction control inoperable.
I just used a CTEK 7002 battery charger from my old Bentley Flying Spur ‘which had a chronic battery drain’ in hopes that this won’t happen again. Codes have cleared for now.
I think it’s either a voltage converter issue or these cars need a trickle charge. I’m also trying the double lock option on the key fob to deactivate the keyless go range sensor from draining the battery. I’ll keep you posted on the results!
To OP, Hopefully that also solves it for you.
https://mbworld.org/forums/s-class-w...ss-recall.html
