Mercedes me connect: Battery Monitor- Charge Status Critical
I've been getting the message quite frequently lately. I've taken it into Fletcher Jones, they had it for two days and returned it supposedly corrected. Yet one day later the engine light appears with many messages of non-operation displayed.
The check engine light went off the following day but the battery critical email comes daily. I purchased the CTEK trickle charger but it only lights up to #2 then the red light comes on. I also have experienced that the door handles do not pop out when I approach the car and have to use the key fob to pop them open.
I will take it back to Fletcher after Labor Day but wonder if this has been a common problem.
Thanks for responses!
If you do get it with normal driving even if you don't drive all that much (I mostly drive on weekends), then something is up with your battery. Unfortunately, I've been told by my SA that MB has made it extremely difficult to get the battery replaced. They have to run a very specific diagnostics test now and MB only authorizes a new battery if it fails that test, and apparently it's very difficult for a battery to fail the test. He told me even cars that are towed in with a drained battery often still pass the test, so all they can do is charge the battery and send the customers on their way. I've noticed that my trickle charger started indicating that I had a bad battery, although I don't have any other symptoms. When it happens I unplug the trickle charger and then plug it back in and then it finishes charging the battery. Not sure what's going on, but as expected it past the diagnostics test, so they wouldn't do anything about it. It may just be the charger.
Lots of people have run into this, it's counterintuitive because it defies what you know about fobs and how they work but it's a thing with the 223.
In addition the telematics and data connection stays active as well, so that you can remote lock/start it at any time. So there is always a certain battery drain and if you have a weak cell signal in your garage then the drain is even higher as it has to boost the signal. Some models have a standby mode now to fully shut them down. I use it in my car when I go on vacation. It turns off all the consumers that stay powered otherwise such as the telematics, data connection and the car alarm.
I can attribute the last two (or even all three) "critical battery" alerts to not driving for two-three days at a time. My keys are in the house, not too far from the garage - is that a problem?
The car must be locked, the fob must be taken out of communication with the car. LOTS of 223 guys have been there: Do this and the doors start working as expected. You stop getting the power messages. The low tire pressure warning that never clears (or any other that should clear on a power cycle but doesn't) will clear because the car will fully shut down where before it would not. It's a thing.
I think the last guy was @Frenetic with this but many have been there, I've been there.
Best bet for convenience is to cage it, also helps prevent theft so it's not money wasted on the next car. Because it's possible you may actually have a fault with the car I'd test first. It's easy to make a ghetto faraday cage with items you have around the house. Use it for a few days and you'll know if car-fob communication is preventing your car from fully shutting down. Like I said though, the handles acting funky is a strong clue that the car is being kept awake.
I shoukd go through the user manual!!
