S500 Trickle Charger Connection
When it hot, the wires are cool, so I’m not concerned.
When Hot or Very Hot are used to describe the condition of an electronic device, it should be concerning.
Very Hot is Too Hot. Warm to touch is just right.
Why is my car doing these things? What is it doing? Why is not in sleep mode? Is this why that damn battery is constantly draining?
In lieu of using the faraday cage for your keys, you can also disable the keyless go/proximity key feature that is draining the batteries in both the car key and the car itself when their radios look for each other by:
- 2021-2022 W223 - Press the lock key twice in succession, the red light on the key will stay on for about 2 seconds indicating keyless go is disabled
- 2023+ W223 - Press and hold lock, then double press the unlock button while still holding lock at the same time
I did this hood latch trick in my garage where I can securely leave my car hood open to charge the car battery for as long as I want. If you are in a situation where you can't leave the hood opened in a secure location to charge your car battery, then the battery post solution you suggested is the way to go.
It sounds like what you are experiencing is normal. I’d keep the keys farther away or get an actual Farady box that seals better? That might help and they are cheap on Amazon.
I don’t have a Fluke to check the temp. of my charger, but 145 sounds about right.
"Now I use a couple of CTEK maintainers, and I attach them twice a month and let them run for a day or more. If I'm going to be away for an extended period of time (2 weeks+) the CTEK is on duty full time.
Lots of folks are using NOCO maintainers, but the important thing is NOT to use a "trickle charger," which will also overcharge a battery."
Also which Tender is most used with the W223? I see quite a few other talking about CTEK for AGM...Not Lithium. Thanks for your time
Isn’t a “trickle charger” and “maintainer” the same thing in modern chargers? I bought the Mercedes one, which I believe is a rebadged Ctek, and it says in the manual that “…the battery charger can remain connected for months in ‘trickle charge’ mode.”
Btw the app shows Charged now...not Partially Charged. I took it car wash less than 5 miles away and back.
The only way I can get the 12V AGM battery to fully re-charge is drive-it or charge the 12V battery from inside the trunk directly hooked up to the battery. This can take up to 24 hours depending on state of discharge to obtain a full charge. I know the charger is functioning properly as it works perfectly well on our other two MB's with AGMs & without the additional 48V lithium battery.
It's like the vehicles BCM (battery control module) is preventing the 12V battery from being charged properly from the engine bay; AGM trickle charge mode or 10 amp mode. 12V AGM battery has been replaced under warranty before & may need to be replaced again. Only 30K miles on the odometer.
It does sound like your battery needs replacing. These 12-Volt AGM batteries just don’t seem to last very long. Not like the old days. I think it’s a combination of much higher loads in newer vehicles coupled with just crap quality in general for these batteries.
If this is the new normal, I may look into a dual AGM battery set-up if the vehicle's hardware & software are up to the task
There is room in the lower trunk area next to the existing 12V AGM battery tub. You would just loose the plastic cover's cubby storage space.This would have to be an after-warranty modification of course.
