Rear HVAC controls plug & play?
https://www.ebay.com/itm/36588956553...BlBMUMik-PCMZw
The installation instruction involves removing the center display to gain access to the HVAC control unit behind it.
I wonder if it's just a duplicate display of what the front is set to.... the seller says it should work as intended if the installation is 'done properly'.
Not sure what that exactly means.
My expectation is that even if this ebay control panel acts as if it's doing something, it will NOT be able to fully adjust the rear passenger zones flow and temps or zones independently the same way as with the factory package. You really need the flap actuators and the large independent blowers which the car is physically missing without the package. Best case is that it may change the front setting but won't be able to independently adjust the flow and temperatures for both zones in the rear. I also doubt that it will direct the flow to foot vs body for the rear without impacting the front.
Perhaps it's going to adjust the front AC settings along the way? But even then I don't see how.... For sure it's worth trying but be careful about adding large aftermarket items like this plugged to your car without enough users/reviewers reporting on it. I feel much more comfortable about aftermarket dashcams separately wired to the panel and fused, or other items powered via a USB port, than aftermarket items wired directly to the vehicle harness.
I think your last paragraph is spot on.
The base HVAC is a 2-zone setting (L & R) vs. the 4 zone climate setting.
The installation instruction shows a bit of a modification to the factory harness (looks like it requires switching the connector from one end to the other)
I think the front & rear will be in sync, both being able to change the A/C settings.
Wow, that's a whole another unit right there.
Kinda justifies the price for the 4-zone climate control!
I just might!
