Are there any Suspension Mods on the S55
Old Oct 27, 2002 | 03:48 PM
alz's Avatar
alz
I am considering the S55 (supercharged) and Have an E55 -- I love the way my E55 handles, but the last generation S55 apparently did not have much in the way of suspension mods -- anyone know what the 2003 has --
Old Oct 28, 2002 | 08:17 PM
///MB's Avatar
2024 S580 | 2024 Escalade ESV Sport Plat | 2022 X5M Competition
The S55 comes with the Active Body Control (ABC) which eliminates almost all body roll.
I think the new S55 will have the ABC with AMG tuning.
If you drive an S class with ABC, you will see how flat the car stays when you turn.
Most likely there won't be any modifications, besides lowering the car maybe.
Old Oct 29, 2002 | 12:32 AM
AndrewEclipse's Avatar
It Varies
AIRMATIC DC semi-active suspension with AMG-specific tuning
To ensure that the high engine output is delivered to the road effectively, the Mercedes-AMG engineers have redesigned the suspension and the braking system. In the E 55 AMG the progressive dynamic handling systems help set the sports Saloon apart from its current competitors. The air-sprung, semi-active AIRMATIC DC suspension with ADS II allows the driver to opt for a more comfortable or a very sporty ride. Damping and springing automatically adjust to the given situation in fractions of a second, and the required tuning can also be selected manually in three stages at the touch of a button. The spring struts, shock absorbers, torsion bars and the entire electronic suspension management have been specifically adapted to the high dynamic potential of the AMG model.
So, yeah, it should be nice.
Old Oct 29, 2002 | 12:46 AM
///MB's Avatar
That is the suspension which is gonna be on the new E55.
The S55 and S600 both feature Active body control, which is even better than the Airmatic DC.
Old Oct 29, 2002 | 01:17 AM
It Varies
Oh, so the suspension is going to differ between the CL55/S55 and the E55?? I thought they were going to be the same. How is the ABC better? Thanks..
Old Oct 29, 2002 | 03:15 AM
///MB's Avatar
Yes, the S55/CL55, S600/CL600, CL500, SL500/55 all have the Active Body Control (ABC) as standard. The S430/500 have it as an option.
The E class has a different supsension called Airmatic DC.
I'm not entirely sure about the technical differences, but I know the ABC uses hydraulic pumps with over 2000psi to virtually elimiate all body roll, dive and squat.
I'm sure the airmatic does decrease body roll significantly, but seeing videos of the E55 in a slalom, and the SL55 in a slalom, you can't compare the two. The E55 still has quite a bit of body roll, whereas the ABC cars stay flat.
I'm sure other people on the board can give you better explanations, but that's what I know. I think if you go to the MBUSA website, they have a animation to explain how it works.
Old Oct 29, 2002 | 03:02 PM
It Varies
Sounds good enough for me. Thank you.
Old Oct 30, 2002 | 09:24 AM
alz's Avatar
alz
Smile Thanks for the Responses -- VERY Useful
I have a downpayment on the new E55 (Number 3 at my dealer) but have an expanding family so I have been considering the S55 --
