what viscosity oil for 03 s55 and how many quarts
Old Aug 12, 2008 | 05:10 PM
cutt's Avatar
dont have the owners manual so i need a little info
Old Aug 12, 2008 | 08:00 PM
jd986s's Avatar
Mobil 1 0w-40, 7.9 quarts
Old Aug 24, 2008 | 05:05 AM
CynCarvin32's Avatar
Mercedes Benz
for pollution reasons it is now 5w-40.
If you have 0w-40 its fine to still use it but all new cars and dealership services have gone to 5w-40.
Old Aug 24, 2008 | 05:19 AM
Untertürkheim's Avatar
I do not believe this is correct, the 5w-40 is 229.51 rated for the Bluetec models. 0w-40 is 229.5, which is the best choice for a gasoline car.
Old Aug 25, 2008 | 02:35 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
You got them switched.....
It used to be 5W-40, but now Mercedes has moved to 0W-40 due to more strict rules to reduce ZDDP in motor oil in order to protect the catalytic converter.
Old Oct 19, 2009 | 02:14 PM
hegar817's Avatar
2003 s55
Would it be ok to use 10w 30 ?
Old Oct 19, 2009 | 04:53 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Not unless you want to void your warrantee. If you do not have one, use anything you want. 10W-30 Mobil1 would probably be ok. I would stick to the 0W-40.
Old Oct 19, 2009 | 06:14 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
10W-30 wouldn't void the warranty, in fact if you look in your MB manual, depending on temps there is wide range of acceptable viscocities recommended. I do agree 0-40 is probably the most widely used. He/she doesn't say where he is so hard to tell if he needs a higher winter viscocity or not.
Use Mobil 1 or others MB recommends.
Old Oct 26, 2009 | 06:55 PM
Mobil 1's Avatar
E320
Mobil 1 0W40 is recomended
5W40 is a low ash oil for CDI and Bluetec
