opinions wanted for new tires - S65
I have 2007 S65 with 12,000 miles and the Pirelli PZero are getting hard and slick.
Im looking for a tire that has the best ride quality. I realize thats a tall order for a 20 inch wheel but I would rather deal with the traction light then getting beat up on rough streets.
Im considering the Michelin Pilot Sport PS2 and expecting 8k at least of use for the 1,800 installed quote.
I was also considering the Yokohama S.drive since I can get theses installed for 880.00
Does anyone have any experience/opinions with Yokohama S.drive ?
Like I said before I want ride quality so cost is not important but if Im going to buy tires every 6-8k and the ride quality is similar than I was thinking of trying something less expensive than the Michelins..., thanks
Nick
I know I'm sacrificing a little traction here....and probably some ride comfort as well, but the 1k trip to Discount Tire every 6 weeks was outta control. I'm having the tires installed this week- I'll report back on my thoughts. Meantime, just be sure the load rating on the tires you're looking at will support the car......I can't imagine you have a whole lot of choices in a 20" tire with the required load rating?
I had also had the sidewall bubbles with the PS2's on my E55.
Get the:
285/30/20 T1R and 255/35/20 T1R
http://www.tiresdirect.net/TOYO_Proxes_T1R_C198.cfm
Then call it a day!!!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
It looks like Pilot Sport PS2 or Bridgestone Potenza RE050A Pole Position because they both have better reviews than the OEM PZero. Anyone else have any feedback on the Nitto Invo ? They might be an option.
Any other recommendations ?
