S55 Dyno Mode
Old Aug 6, 2009 | 07:16 PM
S55-V12killer's Avatar
S55 Kompressor <3 Platinum Edition H2 - C6 Vette - Mustang GT - 06 QX45 - F-350 7.3L 1100 Pnd Ft Trq
S55 Dyno Mode
Is there such thing?
Ive always wondered so i can burnout & do donuts but i actually am gunna start doing dynos as well so i need to know...
im gunna slap a hoe if anyone tells me to push the Traction Control button
(the traction control button doesnt turn traction off all the way)
Old Aug 14, 2009 | 12:16 PM
Oxygen's Avatar
W220 S65 AMG
Alright there tough guy you don't need to slap anyone....
Make sure your MFD is displaying the MILES screen.
Turn Key to OFF
Turn Key to ON
Press the R button (right side of cluster) three times while the SRS light is on:
If you pressed the reset button 3 times while the SRS light is on and you were on the MILES screen, your display will display your voltage:
You can scroll through the various screens using the page up / page down controls on the left side of the steering wheel:
You'll see the car model, engine type, oil level (when running), software versions, VIN # and a bunch of other information:
Last page is the ESP DYNAMOMETER TEST screen:
Using the volume +/- controls on the right side of the steering wheel select ON
Start the car and several malfunctions will display since this will disable ESP, ABS, BAS, BPV and several other electronic controls in the car.
When you are done with dyno mode you MUST disable it... otherwise it will always be in dyno mode. Go to the ESP DYNAMOMETER menu and select W. KL15 OFF and then start the car.
Old Aug 14, 2009 | 12:17 PM
Oxygen's Avatar
W220 S65 AMG
Also I'm sorry that I'm not in Kalifornia... I would make you change your S55-V12killer tag to S55-GOT-RAPED-HARD-BY-A-NON-AMG-V12-SON!
Old Aug 14, 2009 | 01:58 PM
Viet_Amg408's Avatar
Pinto
slap this guy...hahaha I HAVE S55 SUPERCHARGED I WOULDN'T DARE RACE WITH S600. OR S65...
Old Aug 14, 2009 | 07:19 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Turn Key to OFF
Turn Key to ON
Hey !! Great post! That is the best instructions for dyno mode ever displayed! They should make that a sticky..
PS, I ain`t skeeered of the 600
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Aug 17, 2009 | 05:20 AM
hyelifeCL's Avatar
CL600, E30 325i Previous ride CL55 2004
nice! Thanks o2
Old Sep 4, 2009 | 12:09 PM
v12powers's Avatar
S65 AMG
Be careful Oxygen. There is always a faster car. I own a old black 2 door Buick from the late 80's turbo'd just like your car that would blow your doors off. But that is a great post about the Dyno mode.
Old Sep 4, 2009 | 12:19 PM
Oxygen's Avatar
W220 S65 AMG
Of course there is and there's no denying it. Any pics of the said Buick? What does it run in the quarter mile?
Old Sep 4, 2009 | 12:50 PM
v12powers's Avatar
S65 AMG
I am lucky to have the TSM stock block title champion RJC racing that is about 20 min from where I live. his Buick runs a 9.68 with full interior, AC, and is completely street legal. My car Ran 11.2 Two fridays ago At RMR (a local drag strip here in utah) I will post pics of my S55 first (that no one might really care about) and My buick when the Clear coat is done on it. My Name v12 powers refers to anouther project im working on. I am about a quarter of the way through Twin Turboing my E38 750il. And then i will be hunting down a s600 to see how she does. (if I ever get it done)
Old Sep 4, 2009 | 02:14 PM
JAYCL600's Avatar
new balance
damn you guys are a tough crowd
Old Sep 4, 2009 | 02:25 PM
v12powers's Avatar
S65 AMG
nothing tough with me. Just like to Talk a little smack with the smack talkers just like me.
Old Sep 4, 2009 | 02:59 PM
JAYCL600's Avatar
new balance
im joking Enjoy the weekend!!
Old Sep 9, 2009 | 02:53 PM
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
S55 Dyno Mode
Alright Fellas, please educate me. What is Dyno Mode? I've read about it, but (a) couldn't figure out how to do it -- O2 has fixed that; and (b) couldn't figure out what it actually does. Thanks in advance.
Old Sep 9, 2009 | 03:38 PM
Oxygen's Avatar
W220 S65 AMG
Fully disables traction control, disables ABS, disables BAS, presafe, etc...
Basically it's pretty much raw transfer of power Motor -> Transmission -> Wheels
Old Oct 18, 2019 | 05:38 PM
poormanAMG's Avatar
2006 S55 AMG
Turn Key to OFF
Turn Key to ON
Doesn’t work on my 2006 S55......key should not be turned to ON, instead only turned to first position (ON is second position)
