Supercharger Oil
2004 S55 ///AMG, 2007 E350
Supercharger Oil
Please pardon my ignorance with this, but is there a supercharger oil for the 55 engine that requires checking or replacement?
I saw something in the Owner's Manaul re this.
I am talking about the "Factory Approved Service Products" booklet, on page 9 for S-Class(220) it lists:
Supercharger Oil (Engine M113) Mobil Jet Oil II
For other engines such as M111 and M271 engines it lists MB Supercharger Oil, MB part number 000 989 62 01.
Does anyone have any idea what this is?
Thanks.
Thanks.
Thanks.
Thanks.
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
Yeah, there is such a thing, but
apparently, you cannot actually use it, except when you replace your supercharger. I'm told the supercharger is a totally enclosed system, that you cannot open to change the oil, except by replacing the whole system with a new "dry" one, and that's when the supercharger oil comes into play. I only found that out on the AMG Private Lounge, where AMG will actually answer questions.
hey where's that at? i want to join tooo....
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
Super Moderator
supercharger have oil.
I’ve sourced Exxon Mobil’s Jet Oil II for their refurbishment from this outfit...
http://www.aircraftspruce.com/catalo...ilJetOilII.php
care to elaborate?
![word](https://mbworld.org/forums/images/smilies/werd.gif)
This is what I am asking. A Supercharge (Kompressor) is just a set of impellers that rotate to suck in, compress air and force the air into the engine intake for more power. I am not a mechanic but do not think the supercharger needs oil.
However, the MB approved product list in my set of documents lists it as an item. I am just asking if anyone knows what this item is.
move on man...didn't you read the reply?...
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Viet,
You do know that you do not have to read and answer every single post on the Forum, so if you can not contribute anything, let it be and move on dude.......
It seems like you do not understand the post, but I am preaching to the choir.
Over and out.
Over and out.
Super Moderator
You’re correct, Corsa9000.
The impellers themselves require no lubrication, as they do not contact each other and therefore generate no friction between their moving surfaces.
However, the gears at the front of the supercharger do require and have their own self-contained lubricant supply. Thus the specification from MB as to the correct oil specification.
It’s only to be replaced during overhaul, not regularly serviced in the conventional sense.
![](http://i209.photobucket.com/albums/bb196/splintersAMG/55upgrade513.jpg)
![](http://i209.photobucket.com/albums/bb196/splintersAMG/55upgrade506.jpg)
images credit Finny
images credit Finny
whatever i'll reply if i want to..yeah you right, i dont' understand your post....because your post lack of common sense..
I don't know what you are getting at his questions are perfectly legitimate and I have been asked this question in the past. I knew what he was talking about he gave you proof of it's existence. He just wanted to know more about what it is and if it requires maintenance (seems fair). I don't understand why you are dumping on his tread when you flat out said it doesn't have oil when it does. He also said "excuse my ignorance" in the first place so you shouldn't expect it to contain common sense in which I don't think this is common knowledge in the frist place. Now he among others get to actually learn how the supercharger works you shouldn't be some dismissive when people are taking the time to learn more about their vehicles.
See if you can get this link to the AMG Private Lounge thread on Supercharger Oil. It will confirm what others, including me, have said:
http://www.mercedes-amg.com/privatel...t=supercharger
If you want to join the AMG Private Lounge, try here. You'll need your vehicle's VIN to join:
http://www.mercedes-amg.com/privatelounge/index.php
Good luck. Best regards,
scion IQ(five axis), smart fortwo crossblade, austin rover mini
Fantastic pictures and great mini-synopsis of why AMG superchargers require specific oil types.
in addition:
there generally seems to be some sort of failures on these AMG superchargers regardless if one installs after market pulleys or not. WOW, its amazing to know how some AMG owners don't know AMG supercharger's have replaceable oil.
Supercharger Oil (and other sites as well)
Mobil came out with a 3rd generation oil for the replacement of the Mobil jet oil II and a 4th generation is in the line up.
on the Mobil jet oil 254 (3rd Gen.) the thermal properties has been increased with less thermal breakdowns for higher rpm bearings temps/higher temp gears.
so it is possible to have zero failures on these pulley system(and AMG superchargers) with bearing upgrades and/or proper aviation oil change in these AMG superchargers. The more these AMG superchargers are used for track/drag purposes the sooner or earlier for supercharger oil changes. For those who have never seen a supercharger oil change between 5-10 years; look at the gunk that comes out--that is if your supercharger hasn't already failed! (when the car is tilted or with the supercharger removed the gunk can be seen oozing).
So there is nothing wrong using a 185 pulley kit but, however, with a pulley safety kit to slow and sync the entire pulley system(as a safety net)--and with a upgraded idler 100mm from a 60mm. it seems to work quite well on mine. But i never use my AMG on the track or drag strips. I only use it as a pleasure vehicle and for quick passing on the highways. (my AMG r170.2 was not designed for track purposes).
from discussion:
https://mbworld.org/forums/w211-amg/...e-pulleys.html
Quote:
Originally Posted by Mrbig
So it possible that a 168 mm works better because the blower stays cooler and the power is more consistent
Quote:
Originally Posted by 220S
Makes sense that the bearings would wear more spinning faster, but then will it all just be primarily usage (mileage) based? Big question, what's that limit? Kleemann should kinda know the answer, since they made the statement. Or is it simply all theoretical?
Quote:
Originally Posted by AMGSC
From what I gathered, it's the heat and friction that increases exponentially as the rotation speed increases.
Quote:
Originally Posted by jmf003
If you asked the engineers at AMG, they would say any pulley size larger than 154mm leads to premature failure. And they should know: they designed the engine! If the 168mm pulley was perfectly safe, they'd have used it instead of the 154mm.
Bottom line: if you want the longest lived supercharger possible, stick with the AMG pulley. A larger pulley will necessarily shorten the supercharger life. The larger the pulley, the shorter the life.
That's understandable. No doubt there are MB white papers on tolerances with all their components.
fwiw, here's a PSE rebuilder, and looks like they use better bearings(?) Seems like if they can replace bearings, somebody else should be able to.![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
http://www.superchargersonline.com/p...SE-MBZ-AMG-E55
Still kinda pricey, but a lot less than OEM.
in addition:
from discussion:
![](https://mbworld.org/forums/images/buttons/viewpost.gif)
images credit Finny
images credit Finny
