S55 - rev limit on warmup?
Old Apr 15, 2010 | 07:27 PM
CT1's Avatar
CT1
S55
I took a look at a 2003 S55 today. It was behind a billion other cars on the lot and I only had 20 minutes - so I couldn't drive it. I started it and let it idle for 3-5 minutes, then dipped into the throttle a bit just to get a feeling for the sound. The engine wouldn't rev past 4k. I'm guessing there is a rev limiter that keeps things low until the engine reaches a certain temp - can anyone verify?
BTW, 1k-4k sounded very nice.
Old Apr 15, 2010 | 07:45 PM
rondocap's Avatar
Mercedes S55 AMG
Usually when I rev mine when it's on park, and I try to hit the higher revs, the car shakes. I did not look to see if it's at 4k though.
Old Apr 15, 2010 | 09:04 PM
DRTYLNDY's Avatar
Yup it has a limiter when in Park. Put your foot on the brake and put it in Neutral then it should rev much higher.
Old Apr 15, 2010 | 10:54 PM
CT1's Avatar
CT1
S55
Makes sense, thx.
Old May 2, 2010 | 11:55 AM
rondocap's Avatar
Mercedes S55 AMG
Is it bad for the engine to rev it in neutral or park?
Old May 2, 2010 | 05:04 PM
CT1's Avatar
CT1
S55
Only if you fail to intimidate another driver.
(seriously, it's fine but I wouldn't do if often and never when the engine is cold)
Old May 3, 2010 | 12:02 AM
Fast55's Avatar
'06 E55, '05 SLK55, a few others
They won't rev up in neutral or park no matter how warm the motor. It's normal.
Old May 4, 2010 | 06:30 PM
DRTYLNDY's Avatar
I do stand corrected. You can only rev the 55 motor past 4k if you are in neutral and rolling along. I confirmed it myself today.
Old May 5, 2010 | 09:35 PM
hegar817's Avatar
2003 s55
Confirmed too!
Old May 6, 2010 | 09:39 PM
hegar817's Avatar
2003 s55
Originally Posted by hegar817
Confirmed too!
Confirmed it again today!
