09 S65 or wait for a 2011 S63?
HANDS DOWN 65 engine will be better in every way!
The warranty would be a bonus for the 2009 but regardless I would pick the 2009 s65.
Good luck!
Aproximately 200lbs less weight over front wheels does wonders for handling and agility while equalizes the straight line performance with the S65.
Fewer stops at gas stations make life a little bit easier and 7 speed tranny is no brainer vs the old 5speed.
A clean,low miles '09 S65 still costs about $140k+ with warranty that has to be extended while S63 is a virgin for you to deflower....
In the end decided to go for the new engine since the car is significantly lighter where it matters,has superior transmission and does not have to have the silly moon roof and tvs in the back that I would never use anyway.
Performance package and lower weight will make it equal to S65 in straight line and much better in the twisties.
If however, they did to S65 what they should have done,like pump it up to somewhere closer to 700hp,I would go for it in a flash.
considering a TTG at the same time...
S63/S65 is going to replace a wifey's Cayenne GTS.
Also considered a Panamera turbo, but the interior/trunk space
was just too small. But man is it fast!!! Pan turbo felt nothing
like any 4 door sport sedan I've driven to date.
M
I'll be getting a 2009 S65 in about 18 months myself at a fraction of the new MSRP.
S65 faster then new S63?
How do you know?Based on numbers?
Highly questionable considering very small difference in HP and torque,300lbs total lower weight of the S63 and much quicker and more efficient (significantly lower power loss) transmission.
Only time will show,making definite predictions are baseless at the moment.
