S65 Mystic White Designo
Old Nov 3, 2010 | 11:28 PM
pas's Avatar
pas
2007 S65, 2005 Nissan Armada
I am in the market for one of these most likely an '07 due to the cost. I was wondering if anyone can tell me for sure if the diamond stitching was available on '07s or if that came out on the '08s.
thanks
Old Nov 4, 2010 | 01:55 AM
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
I saw an 07 with it before...beautiful.
PL
Old Nov 4, 2010 | 07:37 AM
absent's Avatar
GT63S ePerformance 4dr, '25 Bentayga Black Ed.(wife), Wrangler and 250 MLB(kids)
thanks
Diamond stitching was available starting with '08 model.
Old Nov 4, 2010 | 05:59 PM
gripforce-cl65's Avatar
Fast cars in general....
+1 diamond stitching wasn't available on 2007 model
Old Nov 6, 2010 | 09:04 AM
pas's Avatar
pas
ok thanks not worth spending 25K extra on a 2008 for stitching! Now i just need to find an 07 with the options i want.
Old Nov 9, 2010 | 04:55 PM
Bukwild's Avatar
2003 S600, 1988 RX-7 single turbo vert, 1998 BMW 740IL
most shops do this now for 1k. Its starting to be a very popular upgrade.
Old Nov 30, 2010 | 06:40 AM
GRADY.JAE's Avatar
vvzcdxsdvcx
Then again it might also need its bands adjusted. If you overfill the transmission you need to take out the excess fluid. I use a "Mr. Good Pump" to do that when there's no drain plug on the transmission.
Old Nov 30, 2010 | 06:41 AM
GRADY.JAE's Avatar
vvzcdxsdvcx
Low transmission fluid can cause the vehicle not to move. Wipe the dip stick off, stick it partially (half way) in, start the vehicle, let it idle for several minutes, check the level WHILE the vehicle is running.
Old Nov 30, 2010 | 08:11 AM
absent's Avatar
Are you lost?
