transmission problem??
Old Jan 11, 2012 | 01:31 PM
s55kid's Avatar
04 S55
Drove the s55 for the first time in about two months and I noticed it was a little slow goiing between gears before, but no other issues. Well i was on the highway hiit the gas and it just reved up. It wouldnt take a gear until i slowed to about 30 then it popped back in. But once i was getting home it did iit again but this time it was liike half iin half out of gear it was moving but the revs were not synched with the speed. After getting home ii shut iit down and started iit back up and it moved fine for a few shifts then popped back into nothiing... my initial thought is that its low on trans fluid. But after getting that iidea i found out you cant check the fluid... any ideas what i could do?
Old Jan 12, 2012 | 08:32 AM
DRTYLNDY's Avatar
Well you have two options from the way I see it. Get it to the dealer or Indy to check your Trans fluid level or do it yourself. I opted to do it myself. You can buy the transmission tool on ebay for about $20 to check the level. I believe it is called a 622.4 but can't remember exactly right now.
But if you bring it in for service I would be worried about driving it as it sits now low fluid can be a killer. Good luck.
Johan
Old Jan 12, 2012 | 09:21 AM
mrbenzes's Avatar
2005 S55, 2002 E430, 2007 CLK350, 2006 SL55, 2003 SL55
Get under the car and remove the covers and look for leaks..if there are no leaks, your fluid could be OK. I also have a generic AT dipstick but you will need to know what level it should be anyway, let me know if you need the level, as I marked mine whle it was correct with paint The bad news is if you cant find a leak, your trany is about to go. How many miles on your car?
Mike
Old Jan 12, 2012 | 10:31 AM
s55kid's Avatar
04 S55
the car has 82,000 and it was shiftiing pperfect then it just quit, that seems strange to me usually there is some kind of warniing before that happens
Old Jan 12, 2012 | 10:38 AM
mrbenzes's Avatar
I think you said earlier that it had not been driven in two months....your AT valve body migh be clogged up. Have you ever changed the AT fluid?
If you dont find a leak, check the fluid color and consider having the dealer do a flush...it will probably cost you $500 but may save/postpone a tranny rebuild.
I drive mine at least weekly to avoid this issue.
MIke
Old Jan 12, 2012 | 11:29 AM
babyman1737's Avatar
2005 CLK500 cab, 2004 S600 designo mocha
Have you had the leaky electical plug replaced near the transmission pan?
Old Jan 12, 2012 | 11:34 AM
mrbenzes's Avatar
If it hasnt been changed on an '03 I will 100% guarantee you that it is leaking. My '05 was leaking at 52K miles and never left a single warning drop on the garage floor.
Mike
Sorry, I meant '04
Old Jan 18, 2012 | 11:32 AM
s55kid's Avatar
04 S55
Well guys thanks for all the responses. As soon as my dipstick comes in ill move forward with this. Should have it by friday. I hope
Old Jun 13, 2013 | 10:45 AM
merc79's Avatar
s55 AMG
Mike
Hi Mike, any chance you can share a pic of the dipstick for the Tranny on the S55 you used to get the right level for the fluid? I have the dipstick but unsure whats the proper level it should be at
Old Jun 17, 2013 | 05:03 PM
mrbenzes's Avatar
Sure ill get a pic, or at least measure the depth from the bottom on the universal dipstick...ill get that info tonight while in may garage and post assp.
Mike
Old Jun 17, 2013 | 07:04 PM
merc79's Avatar
s55 AMG
Mike
Thanks Mike , I had purchased the Tranny dipstick long ago when I had an E class, so its the same one for our S55's 5 speed with the same part#.
I appreciate you taking the time out to snap a pic of it. Do you still have the marker on the dipstick where it should be at approximately for proper level of the fluid?
Tariq
Old Jun 17, 2013 | 08:46 PM
mrbenzes's Avatar
My S55 was cold and the dipstick bottoms out and the fluid is just barely on the stick...just below the 25 degree mark...like 1/2 inch on the stick. Engine cold and running...prior to startup it was above the 80 degrees mark on the stick.
MIke
Attached Thumbnails transmission problem??-img-20130617-00393.jpg   transmission problem??-img-20130617-00396.jpg
