Oh happy day! ABC failure. . .
Actually, I'm pretty excited that it happened now. My CPO runs in September, so the repair will be on MB's dime!
Cheers,
Jeff
Mike
When pressed the German instructor said 47000 kilometers filter change but this is a whisper recommendation based on his experience not the official interval.
FYI
Factory Techs recommends NOT doing a flush unless there is a pump, etc. Problem.
( I had the same rear drop problem. I had the car in one of those tin storage garages for the winter while our garage was being finished that i sure went to or below freezing. My previous garage never went below 50f or above 60f. I drove the car in all C modes when i took it out of tin hut when the roads were clear. Just as the weather moderated, the right rear dropped. The storage facility required a plastic sheet under the cat, no leaks. I cycled the car when I got it back. The ABC fluid was 0.4 litre low. The problem went away. Cautious, As below, I had the ABC trained tech change the filter and do a full visual inspection. No problem.
I think temps can have a big issue as well as extreme setting of tires and hitting potholes. I guess that ABC Comfort mode lowers the pressure during colder months so the line and systems' components are less taxed since I guess their materials are less elastic during cold weather. Good luck!)Next step. If you're due for an a or b service make sure they have an ABC trained, most aren't
no matter what they say, tech examine all the hoses, struts, levels, filters etc. For leaks cleanliness etc. "as preventative Maintenance" listed in the MB Service Procedure Sheet that I posted elsewhere, maybe the 215 sub forum. If they want to charge you extra for the inspection the ABC system is hydraulic and not excluded; it says all systems.Finally there are WIS diagnostics that will identify the problem if there is one as OP have posted. I would ask to see them before opening your wallet.
If you search there is a post on WIS codes to du
