ABC PROBLEMS HELP!!!
and i was reading that it could be my valve blocks but i have no idea on what to even think about it please help me out
Had a Rodeo test on it and it showed everything to be perfect. Its the best thing you can do for yours, it will show just how quick the pressure drops and how long it takes for it to build back up again.
Mine was taking a long time to drop but then only taking seconds to build back up again. If it was the other way round i think i would have sat in a corner and cried like a little girl.
My driver rear strut is leaking a bit. I'm trying to hold off a bit til I can replace it. I'd like to be able to just replace the whole system when I can get the money next year.
The car is not slammed but steering is much harder, and this is why I suspect you have a rear valve block issue. Have a professional replace, top fluid and perform rodeo!
Product ID 220-320-12-58
The valve block overhaul is an easy DIY, cleaning and O-ring change.
If the strut is leaking, then you have to exchange it - i've seen on ebay
http://www.ebay.com/itm/FRONT-REAR-S...5ddf97&vxp=mtr
with core exchange its 2K. Not a bad price if you ask me.
At the dealer you're likely to pay around $1300 per strut.
Only issue I see here - S55/S65 AMG's have AMG tuned ABC struts that are different than those on the regular S-Class. I doubt this company would provide you with AMG tuned ABC struts.
AMG cars have an "AMG" logo on the bottom of the strut.
Regarding the part numbers, they are different.
Comparing a 2006 S600 and a 2006 S65 AMG...
S65 AMG Front Left: A220-320-15-38
S600 Front Left: A220-320-85-13
S65 AMG Rear Left: A220-320-17-38
S600 Rear Left: A220-320-91-13
