FS or TRADE: Overhauled ABC Control Valve A 220 320 03 58 (A2203200358)
Overahuled meaning:
1. Aluminum Block and piston, springs/valve piston cleaned ultrasonically
2. New O-Rings Installed
3. Pressure tested on dead weight tester at 250bar
I paid $230 each As Removed and two hours labor aprox per unit.
Make Offers, I can also exchange your old ones. Not trying to make any money of out it - just covering my costs.
(I am FAA certified Aviation Instrument Mechanic and we work on C-130 and P-3 aircrafts, http://av-info.faa.gov/repairstation...ertno=L63R282Y)
In the benz world forum I posted a question about the pumps
C/P here:
Both are ABC pumps, for What I can look up online in terms of pictures they both look exactly the same both made by Luk and on 003 the paper sticker is ixetic and on the 002 its Luk
I checked on epc for both part numbers
Part number: A 0024666001 Designation: HYDRAULIC PUMP
Assortment class Catalog type Model/SA number Mod. des. (digits 4-6)/SA change seq. no.
Car FG 215 373 375 378
Car FG 220 178
Car FG 220 070 170 173 175
Car FG 220 178
Car FG 220 063 065 070 073 075 165 170 173 175
Car M 112 922
Car M 112 922
Car M 113 986
Cross- M 113 986
Car M 113 986
Cross- M 113 986
Car M 113 986
Cross M 113 986
Car M 113 986
Cross M 113 986
Car M 112 944
Cross M 112 944
Car M 112 944
Cross M 112 944
Car M 113 941
Cross M 113 941
Car M 113 941
Cross M 113 941
Car M 113 960
Cross M 113 960
Car M 113 960
Cross M 113 960
And for the 003
Part number: A 0034665001 Designation: HYDRAULIC PUMP
Car FG 230 467
Car FG 230 467
Car FG 230 474 475
Car FG 230 474 475
I looked at the pictures from ebay for both pumps and both are made by Luk with exact mold markings on the back
2108197C and RE2052-1 or RE2052-2
The only difference is that the paper sticker on the front with MB Part number.
Look at this:
http://www.ebay.com/itm/USED-MERCEDE...5509f9&vxp=mtr
and
This:
http://www.ebay.com/itm/MERCEDES-W21...ce40fd&vxp=mtr
Hopefully someone can shed some light on this, as the second part is only used on SL series
So are you buying old ABC valves? I happen to have two I took out of my S55 some time back. I really wish I knew they could be fixed before I went ahead and bought two new ones and replaced them!
Just let me know if your interested.
Johan
Overahuled meaning:
Overahuled meaning:
THANKS
Email me at mcknuke@yahoo.com.
Let me know. I'm in Ptown so could swing by.
Jkgriff72@verizon.net
Overahuled meaning:
(I am FAA certified Aviation Instrument Mechanic and we work on C-130 and P-3 aircrafts, http://av-info.faa.gov/repairstation...rtno=L63R282Y)
Are You still Rebuilding these and do you have any for sale right now?
Overahuled meaning:
I live in Lafayette CA and need an ABC valve block for my SL 500.
Please email and call me at johnrudniski@gmail.com ,925-759-1353, leave message.
I live in Lafayette CA! I need an ABC valve block for my SL500. Please email and call me at johnrudniski@gmail.com, 925-759-1353.
Regards,
John
Do you still have the valve blocks?
I have an SL55 AMG, mechanic told me that I have a sticking rear control valve, they are going to flush the system to see if that fixes the problem.
If not MB does not make that valve block anymore and I'm looking at having to go to an updated design, the problem is that it requires them to change out a lot of the fluid lines going to and from the pump which means $$$$
I'd much rather get a rebuilt one it it's still available.
Thank-you
stratmax@gmail.com
