ABC purge problem after new pump
Current Status: Sourced a new pump and 20 liters of Pentosin CHF11S. MB tech changed out pump and is now having a difficult time purging the system. Prior to the pump exchange (pretest) the car would rodeo but will not now. New pump reads 192 bar and has good flow back to the ABC reservoir. MB tech claims all voltages and signals good. In frustration MB tech has changed out the accumulator and the control unit with known working assemblies. The car is sitting on its haunches right now but didn't have any leak-down on the solenoids prior to service. Lowered stance is only due to purging exercises. The tech can't get the control valves to raise activate the struts. Two separate valve bodies acting the same way? Tech wants to re-install the original pump but I expressed reluctance due to the significant amount of time this will add to the repair. Flat rate, I probably shouldn't care but my gut says something else is going on here and baffling the MB family of techs. The car has been in the shop for over a week now. Has anyone seen this before? I suggested yanking the front valve body and bench testing it but it's likely going to prove to be OK. My experience with similar issues usually yields something embarrassing but I'm still keen to learn from it.
Good Luck
Johan
So the pressure's show they are within spec of what you listed above so the pump is obviously working right. Have you guys tried to open the bleeder valves at each corner of the car (same type as what it used to bleed the brake calipers) to maybe check to see if there is actual pressure buildup on the other side of the lines or pump?
Good luck.
Aaron
My interpretation is that it sounds like system contamination. 33 years ago, I was a mechanic apprentice and one of my instructors made a comment about the replacement of accumulators. "Be sure to remove the internal dust plug". Ever wonder why?
I'm hoping this string will help future technicians understand the consequences of this kind of error. I'm now an electrical engineer and have often compared electrical with hydraulics because that is where I came from. However, I'm at a loss to compare this kind of failure. Maybe a Lightning strike is the best analogy.
